-   -   Cat Hulls (https://www.offshoreonly.com/forums/general-boating-discussion/179341-cat-hulls.html)
Mazz 02-08-2008 12:04 AM
Cat Hulls
Besides allowing more air to pass under; what are the benefits or downsides of a cat hull with a center pod (like an eliminator or DCB) opposed to the side pods only (such as a Skater or Spectre hull)?
Wahoo ATV 02-08-2008 08:31 AM
Not sure of any real advantage to a center pod. The twin sponson hulls allow more air to compress, increasing the speed and are better in rough water since they give more wave clearance. Usually you only see the pod in smaller lake boats.
WildWarrior 02-08-2008 08:53 AM
The center pod helps eliminate porpoising below 85 or 90mph on a larger Cat as well as a great overall stable ride.
Over 90mph packing air the center pod on my 37' rig isn't even touching the water until a hard turn or rough water.
Rough water is where the traditional tunnel hulls will ride much much better,over 3' surf my boat will pound you hard as hell .
In the 3' + water a 36' Skater feels like a magic carpet. Twice the hull efficiency with a true tunnel vr a center pod.
We make up for the lack of efficiency by running ultra high HP and a correct set up, drive ratio ,props etc...
glassdave 02-08-2008 08:54 AM
some center pod cats are single engine boats and it is there to accommodate the engine and drive as well.
Propster 02-08-2008 12:09 PM
I have a 25 foot center pod cat. I really like it in smooth to to 2 1/2 - 3 ft waves, accelerates hard, good low speed handling, little or no porpoise, great top end.
Can't really run over 30 mph in over 3 ft waves. Just when you think everything is fine, you can hit a rogue wave, sky the front, trip and stuff. If only one sponson gets stuffed, it can spin out. Just have to be real carefull in the rough.
I had a small Skater before (21), loved the rough water ability, hated the porpoise and low speed handling. It wallowed like it was full of water at under 45 mph and porpoised right at the speed I like to cruise, 55-70 mph, drove me nuts.
What hull is better depends on the water you like to run in.
VetteLT193 02-08-2008 12:38 PM
I understand the center sponson has something to do with slow speed turning too, but I could never figure out the physics myself.
Brad Zastrow 02-08-2008 01:10 PM
This quote is 100% on the money. I have owned both and l prefer true cats at high speed and rough water. On smoother water the modified tunnels (pod) are really nice.
monstaaa 02-08-2008 01:19 PM
the center pod also helps keeps the center engine in a triple engine outboard application from shearing off gear cases
Croozin2 02-08-2008 01:35 PM
That's strange. We used to run the smaller tunnels (or modified V, or Mod-VP) with a center pod (STV) and the pod was actually lower than the outer sponsons - hence the name, modified V. Be interesting to hear the different thinking behind the different designs.
glassdave 02-08-2008 02:05 PM
Mod VP's like the STV's run with just the pod in the water and with the sponsons in the wind. totally different from big cat dynamics, some of those little things really hang it out there :D
Croozin2 02-08-2008 02:19 PM
True dat!! Had mine hung out SEVERAL times!!! Mucho glass repair done on one of 'em!!:D Roark Summerford built a hell of a little boat though.
24skaterVA 02-08-2008 03:55 PM
An STV is still considered a v-hull & still rides on a pad at the back of the V. The hull style they are talking about is more like a talon which is a cat w/ a center "pod".
I think the biggest decision maker would be on where you plan on running the boat.
Croozin2 02-08-2008 04:05 PM
Understood, that's why they call them modified V. I raced them for years. But, it is still a form of air entrapment hull, although not a "true" tunnel. My point was I'd like to hear the thinking and hydro/aerodynamics behind each design and the + and - of each. Sounds like a winter research project!!:D
24skaterVA 02-08-2008 05:02 PM
We had river rocket go 132 w/ a drag 300 & a hit of gas. :D
They are awesome machines. Maybe I can get into all the differences later tonite after a couple beers.:cool-smiley-011::ernaehrung004:
Croozin2 02-08-2008 05:10 PM
Always better to talk technical stuff after a couple beers!!!:D
Mazz 02-08-2008 05:21 PM
Thanks to all of you for your information on this center pod question of mine. Sounds like you guys know a just a bit more about these cats than I do. If anyone has more to add, please do, I'm listening...
Cat man do 02-11-2008 01:28 PM
CENTER POD IS TO HELP BOAT GET ON PLANE AND PREVENT HOOKING WHEN TURNING THE BOAT LEFT OR RIGHT, CENTER POD IS SAFER MORE STABLE AND EASIER TO DRIVE. MARTY:drink:
Croozin2 02-11-2008 01:42 PM
Damn Marty, I wish you would have told me this back in the early '90s. Would have saved me plenty of money and aggravation!! Mine tended to spend a lot of time back in Hendersonville !!:D:D
Actually, the center pod on the STV Mod-VP race hull was different than the production river rocket and ski boats. Wouldn't quite mph as good as the others but holy s**t would it turn!!!
One of these rainy days I'm going to spend some time at the computer scanning in some old photos. Racing sure was a lot cheaper in those days!!:cool-smiley-011:
WILDMAN 02-11-2008 10:38 PM
Liberator recently came out with thier new 30ft cat and put a small centerpod on it. It's 10" higher than the outside sponsons, but completely eliminated the hop in flat water. Still has a very deep tunnel for rougher water.
http://aycu30.webshots.com/image/438...7870766_rs.jpg
http://aycu06.webshots.com/image/414...9630839_rs.jpg
Croozin2 02-12-2008 07:11 AM
Wildman, where was that pic taken? That is some crystal clear water!
WILDMAN 02-12-2008 08:33 AM
That's Silver Glen Springs off the St Johns River in Florida. The water stays 72 degrees all year. On weekends, there's hundreds of boats in that one small section.
seltzer 02-13-2008 06:49 PM
Wildman, thats one bad a$$ ride! Miss my 18 talon.
seltzerII 08-08-2011 10:19 PM
Any small cat hulls like a stv for sale please email [email protected] thnk tyler
WILDMAN 08-09-2011 01:05 AM
I sold a 2010 18 Liberator to a customer a year and a half ago. He has still never put a motor on it. He paid $22K for it without a motor. It's custom rigged and custom painted. He says he will take 15K for it. He will put a 2002 300x on it for anothe 10K. It has been in the garage since new. His name is Brad. His phone is 561-541-5393. He can email you the pics. It will run 118-120 with the 300x.
SHARKEY-IMAGES 08-09-2011 08:19 AM
:drink:
http://sharkeyimages.zenfolio.com/im...68895849-4.jpg
chewiekw 08-09-2011 11:56 AM
Does someone have a picture to show me what a center pod is? Or a side pod for that matter.
Xray50 08-09-2011 01:40 PM
Pic of center pod
1 Attachment(s)
Here's is a 26' American Offshore with a center pod.
seltzerII 08-09-2011 03:09 PM
For sale?
Xray50 08-11-2011 01:02 PM
26' Ao
For sale, no!
stripp 08-12-2011 10:07 PM
Stv
Seltzer - If you are seriously ready to buy an STV, give me a call. Wally Lamkin (Triad/STV) is a very good friend of mine. If anyone knows of one for sale it would be Wally. He would also know the history/abuse level.
Steve Tripp
Revolution Performance Marine
(205) 672-8763
seltzerII 08-18-2011 09:42 AM
Thanks. anyone ever heard of a 18ft spectre cat? one guy says he has one for sale 5,500?
mikesufka 08-18-2011 11:58 AM
You might want to check www.screamandfly.com. They always have STV's for sale over there. You probably already knew that.
Here's my old STV. It's also for sale. Great boat.
http://www.screamandfly.com/showthre...-245-carb-merc.
Mike
seltzerII 08-30-2011 04:10 PM
Nice boat. For sale?
MrSneakAttack 08-30-2011 05:31 PM
stripp
i like your boats....they have a 26 that runs on the river were i live....do you have any 26fters for sale?
stripp 08-31-2011 12:09 PM
Originally Posted by MrSneakAttack (Post 3492127)
stripp
The only boat that I have right now is the one that we ran at LOTO in the NA class. It has a Ron Sporl 565 ci carb motor in it. It runs 110-115 MPH depending on weather conditions. Give me a call (205) 672-8763.
Steve Tripp
seltzerII 08-31-2011 03:37 PM
any cat boat for sale send pics
