-   -   B-Max drives??? (https://www.offshoreonly.com/forums/general-boating-discussion/182028-b-max-drives.html)
SinkorSwim 03-13-2008 08:54 AM
B-Max drives???
Good? Bad? Thoughts?
Can they take 750 hp?
BBB725 03-13-2008 09:00 AM
They will handle 750 hp without a problem but you will lose a couple mph with them.
KAAMA 03-13-2008 09:36 AM
Also, you can do a search on B-Max and you should find a few threads/discussions with pros and cons about their drive.
Canada Jeff 03-14-2008 06:28 AM
The only 'con' is the lower gear set isn't any larger than a standard bravo XR drive. So if your blowing lowers, keep this in mind.
Just my 2 cents.
pasquesi 03-14-2008 11:55 AM
Just my 2 cents.
You have some experience in this department, blower boy?:D::evilb:
Strip Poker 388 03-14-2008 12:30 PM
3 Attachment(s)
They have a 1 year warranty up to 950 HP and TQ.You can also buy a extended warranty that is reasonable:D
Back4More 03-14-2008 03:22 PM
Strip, Quit hoggin all those for yourself.
Strip Poker 388 03-15-2008 07:45 PM
stock is getting low:evilb::evilb:
Canada Jeff 03-17-2008 07:13 AM
I break uppers....so far....
racer-x6 03-17-2008 07:33 AM
Why do you need so many if they are so good:evilb:
