SBC startup w new Dry Pipes >
Old 03-22-2008, 12:24 PM
Default SBC startup w new Dry Pipes
The boat is ready to hit the water now. Waxed, new motor in and new HD drive on. I fired it up yesterday to make sure everything was right and to see how the new dry risers sounded. It's pretty mean and should help a little bit in the HP department. I'm just glad the reversion is gone. With the 22" extensions onto the short risers the water mixes with the exhaust in the last 2" of the tip. Weather looks promising for next weekend. Sunny 60's so the water test is not far away.
http://www.youtube.com/watch?v=ORkMT3JMWu8
Engine Specs....
010 4 bolt SBC, bored .040", 0 decked, line honed,
ESP 4340 3.750 crank, ESP 6" 7/16" H beams, Mahle forged FT's 5cc, C77H bearings, Hines Balanced
Melling Racing #10555 oil pump, Hamburgers 7qt marine pan, full length windage tray.
FluiDamper harmonic balancer,
AFR 190cc heads, 73cc, further ported by Carl McQuillen Racing Engines, Isky 6105 dual valvesprings,
Marine Kinetics "RMbuilder" custom Hyd Roller 234/240 .580/.568 112+4
Morel Retrofit Hyd Roller lifters
Smith Bros .083" wall pushrods
Edelbrock RPM Air Gap port matched to AFR port
Holley HP 750 DP
Lunati Voodoo Widebody 1.5 roller rockers
GLM aluminum manifolds
FastGlass Stainless 22" long dry risers
Full MSD ignition setup, coil, wires, dist, 6AL,
10.07-1 SCR
Ryan00TJ is online now
Old 03-22-2008, 12:34 PM
Sounds nice and healthy........ can't wait till spring....!
Here's Johnny is offline
aTX427
Swap Shop
3
09-03-2008 10:12 PM
aTX427
Eliminator
0
07-17-2008 08:25 PM
aTX427
Fountain
2
05-22-2008 12:31 AM
OldSchool
05-16-2006 11:43 PM
thisistank
Baja
29
12-18-2002 10:28 PM
Quick Reply: SBC startup w new Dry Pipes
