-   -   Best Way to Strip Outdrives? (https://www.offshoreonly.com/forums/general-boating-discussion/182909-best-way-strip-outdrives.html)
pshannon 03-24-2008 08:37 PM
Hey guys my outdrives need a good repainting so I want to strip them down and repaint them in mercury black...So what do you guys think is the best way to take the old paint off?
I might do black/silver I don't know..
http://i10.photobucket.com/albums/a1...ormance007.jpg
comininhot 03-24-2008 08:43 PM
Lett me pull them off and you can blast or sand them in youre garage and then hang them or put on engine stand I will lend you one, call me.
US1 Fountain 03-24-2008 09:26 PM
I'd lightly sand the original paint and shoot over it if possible. That original paint is hard to get off and is 200x more durable than any paint you put on it. It'll make for an excellant base.
jeff32 03-24-2008 09:46 PM
My first thought was 1500HP...
Until I read the tread!:D
DollaBill 03-24-2008 09:50 PM
Absolute, Tequila, my portable stripper stage and any other things you might enjoy.
Oooooh, you said outdrives............. :)
pshannon 03-24-2008 10:24 PM
Well if we are going to do that then we should do new seals and an impeller while they are off to right?
Chris Sunkin 03-25-2008 02:18 AM
The drives are powder coated. The best way to get powder coating off is the same way it went on- heat. Take them to a powdercoater and let them put the drives in their oven- 400 degrees or so should do it. The stuff will just fall off. Plus, you'll leave the conversion coating that's applied to the drive for anti corrosion intact. Sanding or sandblast will remove it
Roger 1 03-25-2008 08:08 AM
Are you sure that Mercury powdercoats their drives? I was at Mercury Racing for a tour last spring and they said that they did'nt powdercoat but painted them.
cigrocket 03-25-2008 08:26 AM
Konrad powder coats, mercury does not.
ARTnPARTS 03-25-2008 09:36 AM
contact Doller Offshore, they can paint and redecal the trs like it was brand new ( as long as the housings aren't pitted etc)
