Boat V Car Motor
Can somebody tell me the diff. between lets say a 500 H.P. boat motor and a 500H.P.drag car motor. Thanks
freeze plugs and tolerances are the 2 big ones
ones in a boat and ones in a drag car
Drag car 1/4 mile. Boat at least double.:evilb:
One is made to go full throttle for 8-13 seconds.
One is made to go full throttle for 150-250 hours. |
One has torque on it for about four seconds then it shifts...torque again for another six seconds and its over.
The other has CONTINUOUS torque on it for many hours of pleasurable fun..................until it lets go on the bottom end:( |
Torque and HP curves are very different. Generally i believe they come in much lower and there is more separation between the peaks in a marine engine.
(Post 2499650)
Thats what I would say,most drag big blocks in the 500 range I would say peek around 6500,unless it was a purpose built low rpm motor |
A 500hp drag engine is simpler to build and can be done pretty easily with a small block. You can spin it to 7000rpms and don't have to worry about reversion caused by the cam or having it idle at 800rpms.
So in other words boat motors are built totaly different or just a little different ?
Totally different. That is why race car engine builders have a steep learning curve, usually on your dime, when they first get in the marine engine business.
Another difference not mentioned yet is...
about 15k if done correctly. |
They are the same.
The biggest difference is price, once you add the name Boat or marine to anything you can charge double.
Originally Posted by 24skaterVA
(Post 2501152)
They are the same if ya dont mind rebuilding 6-7 motors per season.......
| All times are GMT -5. The time now is 02:50 AM. |
