Like Tree0Likes
Advise on Switching from Cable to Dish
Old 02-19-2002, 01:44 PM
birdog's Avatar
My Boats: Top Gun
No tree branches. I thought had it mounted pretty solid but maybe it has moved a little? I guess just a skooch will screw it up? Thanx.
birdog is offline
Old 02-19-2002, 02:07 PM
My Boats: boats,cars...speed
Maybe I'll just put one sat. out on my garage....Fred
fred is offline
Old 02-19-2002, 04:02 PM
Raypanic's Avatar
My Boats: Formula 400SS Eliminator 236 Eagle XP
This set up is true two way high speed and does not require a modem.
http://www.hns.com/direcway/intro.htm
Ray
Raypanic is offline
Old 02-19-2002, 05:01 PM
Charter Member #232
Audiofn's Avatar
My Boats: 1979 Formula 302, 99 Formula 353, 81 Donzi 18 2+3 with 454
Kcotch: The satelite is two way. If you go back I posted the up and down speeds. Both of those are through the sat no phone line required. The cost of the set up with the dish, rec. and all the network hardware you need to hook it to your computer is going to run around 799-1000 bucks depending on your dealer. The service including sat. programing is 100 a month. Not bad for all that.
You can hook up as many recievers to one dish as you want. It requires a special splitter but one dish is all you need.
You pay your service that you want for one dish
Any additional dish is 5 bucks and that includes local channels
If you use the proper multi switch you can all be watching what ever you want.
If you are not going to order pay per view you do not need a phone line hook up. If you do need phone and you do not have a phone line at the TV area you can use a special plug that will allow your phone lines to be shot over your high voltage lines in the house. This will allow you to have a phone were ever you have a plug
If you have cable were your TV is going you can piggiback the sat onto the same wire and save yourself a lot of headaches. You can even have cable and sat running on the same wire if you want to we do it all the time and there is no losses with it.
Jon
Audiofn is offline
Old 02-19-2002, 05:35 PM
Charter Member #737
KCHOTBOAT's Avatar
My Boats: 28 Apache
I was wrong, I knew about V sat. but not consumer models.
KCHOTBOAT is offline
Old 03-06-2002, 11:37 AM
My Boats: 99 Baja 272I
Default Im making the switch
from Dig cable to DishNetwork.
Going with the equipment rental program, 5 bucks a month. Otherwise the upfront would have been steep for 3 rooms and STB upgrades. 3 free months and a one year commitment.
WRedmann is offline
Old 03-06-2002, 11:43 AM
BODYSHOT1's Avatar
My Boats: Thoroughbred/Velocity 32'
we just hooked up with Comcast Digital Cable a few months ago and it's a pain in the ass!
BODYSHOT1 is offline
Old 03-06-2002, 11:55 AM
Chris288's Avatar
My Boats: 2005 288 SUNSATION
Default There are cheater cable boxes,,, how about cheater dish's
any such thing ??
Chris288 is offline
Old 03-06-2002, 12:02 PM
Charter Member #232
Audiofn's Avatar
Yes they do make cheater boxes for Sat. They run anywere from 200 on up. Make sure you do a lot of research before buying them as they can require reprogramming from time to time and that costs. THe more expensive ones do not require reprogramming.
Jon
Audiofn is offline
Old 03-06-2002, 12:11 PM
My Boats: Spectre Sportfish Tournament Edition
I recommend the Sony for your main box. It is MUCH faster and has more bells and whisles than the other brands for DSS. I have had DSS for over 5/6 years and I love it. It beats cable any day of the week and the price is the same for a fully loaded subscription but you get a lot more from DSS. Also make sure that you get the remote that is radio controlled with the Sony! It's awesome!
Vyper340 is offline
MOERON
02-05-2008 06:18 PM
DrFeelgood
Drives and Lower Units
5
11-05-2007 10:42 AM
Anarchy Powerboats
08-25-2006 08:13 AM
32 thunder
10-08-2004 09:29 PM
