Like Tree13Likes
Evinrude ETEC 250HO - Twin power choice for a 28 Skater???
Old 04-30-2008, 08:18 AM
Charter Member # 545
Beak Boater's Avatar
Aren't the water pickups on the E Tec. sides of the gearcase? That would at least cause you to put low water pickups on it, if you run it on a Cat. Not sure, arent many Rudes in our area.
Beak Boater is offline
Old 04-30-2008, 08:15 PM
monstaaa's Avatar
My Boats: 3kids
i'm sure you can nose cone the gearcase as has been done so many times in the past for the rudes. i did my own bob's back a lil ways.
i say try it.
course its not my money, so be carefull.
but theres always somethin with bein the first to do it!
monstaaa is offline
Old 04-30-2008, 09:04 PM
What's the weight difference between the two?
stainless is offline
Old 05-02-2008, 12:12 PM
T2x
Allergic to Nonsense
T2x's Avatar
My Boats: 1966 !8' Switzer Wing "Miss Diablo" 1968 Switzer Wing "Dust'n the Wind 2",, 1960 Powercat 15C , 1977 17' Molinari w/Evinrude CCC
1. Skaters like a low C/G.... the ideal setup is a 15" motor on a 28 Skater and 20" is the maximum engine length for that application.
2. With the largest available stock prop (34") the 300 XS Skater28's peak out at about 110mph at 6300 Rpm with 1:62 gears. Doing the math quickly, that translates to 99 mph at 6000 RPM with 1:71 gears...... However the 1:71's are only available on the 250 hp model so figure a 10 mph speed loss (and lower pitch) due to the HP loss......
Figure you will have a mid to high 80's boat...... not much for a 28 Skater....Especially considering that the old 300x motors (not XS) like mine, run north of 120.......
T2x
T2x is offline
Old 05-24-2008, 07:24 PM
Trade Score: (3)
oceanoutlaw's Avatar
I would have to agree with the math of t2x. You may also want to consider the mid section. The two small trim rams on that three ram system tend to mushroom over in offshore applications. You would also have to come up with some solid motor mounts. just some food for thought
oceanoutlaw is offline
Old 11-08-2013, 05:04 PM
My Boats: 27'Progression w/ 2014twin outboard ETEC HO 250's
I ran a 250 HO on my 24' SuperBoat all summer. This motor replaced a 250efi Mercury with a brand new torque master lower. The 250 HO so out performed my Merc motor i was embarrassed for Mercury an when I say out performed boat was ten mph faster way more torque an the boat definitely handle better no comparison......
Omni Present is offline
Old 11-08-2013, 09:31 PM
noli's Avatar
I'm beginning to see the positives
[ATTACH=CONFIG]512041[/ATTACH]
noli is offline
Old 11-09-2013, 08:11 AM
Trade Score: (3)
My Boats: 33 Powerplay Sport Deck
Quote:
A better comparison would be a 250xs vs the 250HO. a 250efi is an ancient motor, it a 250efi is more comparable to a 250 ocean runner.
turbo rr is offline
Old 11-09-2013, 08:41 AM
We race them here in that states and in the UK. The moots run strong. However there are short comings. In rough conditions they will break off the clamps and steering tubes. We have had to make new mounts also. The power head is strong. Not a lot of breKage. The weak point is the transom assembly. We have reinforced it to make it last. We have put over 160 hours at 6200 rpm wit little power loss. Make sure you use the xp 100 oil and set the computer so it knows it has xp100. Gives less oil and better performance.
Lowers are fine just put a bobs cone on it. You can surface it then. Send your computer to DBR and set the rev limiter to 7200 and he will re map it. Makes around 300 hp then.
SVL-WARLOCK is offline
Old 11-09-2013, 08:45 AM
Quote:
I have to agree! I am in the process of putting twin 250 HO ETEC's on my 27 Progression an the only other 27 Outboard Progression on Long Island is sporting 250xs. So maybe sometime next summer we'll be able to put the speculations to rest.......
SRT10
Sutphen
8
06-16-2008 11:46 PM
Sherlock
08-01-2007 03:15 PM
cri331
6
03-10-2003 04:07 AM
cri331
Skater
8
03-05-2003 11:18 PM
timucin
26
06-12-2002 07:02 PM
