Raising the X
I'd like to know if anyone on OSO with a twin engine 30ish foot boat changed their X dimension, by how much, and what speed they gained.
I have a Sonic 1988 30SS and am thinking about raising the X by one inch. The boat is also getting Bravo I 24 pitch four blades fitted to the new Bravos and Scorpion motors going into it. Any other prop suggestions? Thanks in advance. |
I raised propshafts 2", 30 Excaliburcat with TRS. This is what happened:
Before, propshafts 6.5" below hull 25 Mirage, 80 @ 5200 27 Mirage plus, 80 @ 4800, 66 @ 4000 29 Mirage plus, 78 @ 4300, 74 @ 4000 26 Bravo one, 78 @ 5000 After, propshafts 4.5" below hull 25 Mirage, 83 @ 5500 27 Hydro Q IV, 84 @ 5000 28 Bravo one, 82 @ 4800, 68 @ 4000 27 Bravo one, 82 @ 5000, 63 @ 4000 I would say that raising the drives gained 3 mph, but Mirage props would blow out, hard to plane with a load. Four blades were needed, slower, but got the planing back, little blowout with Hydro, none with Bravo. You lose ability to trim the bow as you raise the drive, not a problem with a cat where bowlift is by air, but you may not like it. Hydro had the least bowlift/ most sternlift. Was the fastest but I didn't like the way it felt, especially in calm water. All tests with props turning inward at the top, supposedly gives the most bowlift, maybe a bit more speed. I would try a bigger diameter three blade at the raised position if I could find one. The 29 Mirage plus is 15" diameter instead of 14.5", but I don't have enough power to use it. |
Great information TOMCAT, thanks!
Anyone else with a V hull raise the x in their boat? |
| All times are GMT -5. The time now is 04:54 AM. |
