-   -   carbs.. carbs and more carbs.. (https://www.offshoreonly.com/forums/general-boating-discussion/186778-carbs-carbs-more-carbs.html)
YOLO 05-15-2008 04:09 PM
Ok..I wondfer if this is an easy fix or not...
I am crusing about 15-20 mphs... nail the throttle down and the engine bogs down... almost stalls.. like it is getting to much fuel to quickly.. can anyone tell me what I can look for as a possible fix..:(:(:(
BY U BOY 05-15-2008 05:36 PM
I would check to see if your timing is advancing.
Deltarat 05-15-2008 05:37 PM
check your power valves?
Westcoast 05-15-2008 05:38 PM
Originally Posted by BY U BOY (Post 2559397)
I would check to see if your timming is advancing.
What he said...timing
Thunderstruck 05-15-2008 05:43 PM
Accelerator pumps working? Power valve leaking would run bad all the time and make lots of soot on the transom. Lack of accelerator shot or too much would produce the same effect as would the lack of timing advance.
Also, have you done any work lately? Wrong spark plugs for example? Short plugs when the heads need long plugs. If you have performed maintenance recently look at what you changed.
Brad Zastrow 05-15-2008 09:12 PM
Sounds like accelerator pumps. They go bad over time and when they do not work it will lean the engine and bog real bad on a hard acceleration. I bet if you accelerate real slowly there is no problem.
fund razor 05-16-2008 10:14 AM
Is it related to a bow lift? (ie: you nail it and the bow comes up and it starts to stall?)
If so.... dump the water out of your separator. The gas floats on top of any accumulated water. The gas runs over the top of the water, but then when you go to hit the throttle the carbs get some water.
Maybe instead of "too much fuel" it is not enough because of the water.
fund razor 05-16-2008 10:16 AM
BTW... YOLO is running an OMC 5.7 with shift assist and a holley carb.
I only know this because I keep trying to help him with every problem, since I used to run OMCs.
Knot 4 Me 05-16-2008 10:18 AM
Accelerator pumps most likely culprit. Ignition not advancing properly would be the second thing I would look at.
Airpacker 05-16-2008 11:03 AM
Acc pump not squirting. Ports probably full of last years scunge gas.
YOLO 05-16-2008 04:18 PM
Thank you all for your replies..
At first I think my accelerator pump was not working right as it was not pumping very much until the boat ran for 3-4 days here and there.. I was pumping the gas at the carb and seeing very little fuel coming from the jets.. now there is lots...I think it is getting to much...
What can I do to fix that??
The carb is not very old..Edlebrock ( which is really what a quadrajet in disquise...!!)
if I ease into it the engine runs fine..
spazboz 05-16-2008 08:51 PM
Time to rebuild the carb. As mentioned before, don't forget to replace your fuel/water separator also.
