HP 500 Question
2000 HP 500 carb motors. Valve springs were done at 200 hours. The motors currently have approx just under 400 hours. I was toying with the idea of a refresh over this past winter and was told to wait another season. Is there a concern with doing a poker run, running at around 4000rpm's for an extended time and beating the motors this season or should I take it easy season?
I had asked a similiar question. The answer I got was after the initial valve spring/valve job, these motors are good to go for quite awhile, afterwards...assuming proper maintenence etc. Good luck!
Originally Posted by formula1
(Post 2566951)
What is "quite a while" should you take it easy at 400 hours? or it doesnt matter. |
I don't know. The boat I'm getting ready to purchase is a 1999 Baja 272 w/HP500. I don't know exactly how many hours it has (it was used, probably not low hours), but it was freshened about 100 hours ago and I got the impression to go for it! :cool-smiley-011:
Check out this thread I started not long ago...
http://www.offshoreonly.com/forums/s...d.php?t=186742 |
| All times are GMT -5. The time now is 01:16 AM. |
