-   -   ignition help please (https://www.offshoreonly.com/forums/general-boating-discussion/187462-ignition-help-please.html)
grapeape93 05-25-2008 03:45 PM
First start of the year, the starboard ignition on my 32 fever does nothing. No gauge check, zero. Tried replacing ignition and breaker still no luck. Port side is fine, everthing else electrical works. Any suggestions before I take it in! Thanx.:confused::confused:
HighPriority 05-25-2008 03:53 PM
Check the fuse link at the starter, and alt.
JIMKID Motorsports 05-25-2008 04:59 PM
check all your grounds take them off and clean check kill switch
bowtie 05-25-2008 05:42 PM
Kill Switch? Probably you have one switch for both engines. Make sure the batteries were connected properly, all cables connected. Check the plug on the harness has not come loose. If you have a test light check on the back of the ignition switch for 12 volts.
