Only made 720 hp with my Whipple??
Registered User
1 Post
Actually you are with in less than 3% what is advertised. Not being a Engine guru, I would say thats awsome with out spending allot of time making adjustments. My concern would be all the Tolerences that seem to be changed, we all know that adjusting this can rob some HP, if I had to guess that is what happened and once the motor is broke in you will see the 20hp, who knows maybe more??
Really hard to compare a stock 500efi/whipple set up to a 500efi/whipple set up not exactly stock. Cannot tell youhow many times changing something in a engine that should have made more power actually made no gain or less for no real reason???????
My 2 cents
WILL
My 2 cents
WILL
YOur right in the ball park. The cam is restricting you and I would suggest running your CMI headers to get a more true Dyno reading. Dean Gellner (MR. Horsepower) doen all my work and always runs the marine exhaust when tuning.
I've got a similair engine in pieces in my shop right now. Stage two with merlin heads and stock cam. The dyno sheets from the "builder" show anywhere from 713hp to one mystery pull that made 789, and a bunch in the 730hp-740hp range. This was over a few days and really shows how much a bad dyno setup or operator can skew results. There were 30hp differences between back to back pulls without any tuning changes. Sometimes just changing the rpm/sec rate of the pull can show unrealistic results. Unfortunately they left the iron guides in without inconels and .0015 clearance. It lasted about 40 seconds at full throttle and grabbed a valve. Enjoy the blower whine..
You could easily take fuel psi away for a dyno run, but it in fact needs to be setup the way it is in the boat.
Get the AF right and you'll see closer to 750+ HP, but again, it's calibrated for operation in a boat.
Thanks,
Dustin
Don't get me wrong here, not complaining, I just thought I would see more than 720 hp. Here's why. Keep in mind, Whipple advertises 740 with their stage 2 kit and a stock engine. Here is what I've got.
Hp500efi, with Dart aluminum heads, port matched to Whipple intake . Stock hp500efi cam. New 502 block deck honed and rotating assembly balanced with all bearings within tight spec. all piston rings special end gap type for specific fit. More about the build here http://www.speedwake.com/upload/show...threadid=53577
so here is the dyno pull. there will be an AFR adjustment once more around the 3000 rpm range to even it out.
So am I wrong to expect more? And again, tons of power, and I know its going to be strong, just wanted to share this with others.
I just noticed that you have Dart Pro 1 heads. If thats the case, and you DID NOT change the SC pulley, then you've lost almost all velocity through your heads. Those heads flow significantly better, but you need to keep the air speed up. By not changing the blower pulley, you kept airflow exactly the same, yet lowered the compression of the enigne and the temperature of combustion.
Aluminum heads need to be run leaner, they need some cylinder pressure to work properly. Changing to the different heads should allow you to install a 1/2" smaller pulley, which would put the boost up to 8psi, which will net another 50-75hp.
Remember the SC is the pump, if you don't change the speed of the pump, you WILL NOT get more air through the engine, therefore, changing heads to aluminum just lowers combustion temp, higher flowing head just causes loss of velocity, etc.
Put a pulley on it and watch it go.
Dustin
The Merlin's won't make as much as the Dart's but because they're still cast iron. The boost doesn't drop as much. But, will make more power if Canada Jeff doesn't change the pulley because they keep combustion temps up.
Thanks,
Dustin
Geronimo36
Dustin
Dustin
Quick question... Theoretically, if he has better flowing heads than stock wouldn't he make less boost and potentially more power with the same pulley since more air can get into the engine with less resistance? In the end he would make more power with less boost?
Then again...even if the heads flow better, now the cam would be limiting his power output?
Frank
