External steering question..
Charter Member #601
mlitefan,
The answer to that question is all relative. If you consider what happens when the steering breaks at say 50 or 60... well then external is the way to go. But steering rarely breaks if it is in maintained in good condition. The higer speeds will put stresses on the steering so that is also a factor. I had a single ram external steering when my gimble broke at 80mph. The result was a serious head injury.
They say no matter what when the big black thing in the back that steers the boat either falls off or the connection to the wheel is lost it will be a violent reaction. I agree with that statement because I experienced it. I have friends that run 100mph with stock steering.
I feel that anything above 70mph will warrant external steering depending on how and where you drive it. Running on flat water will not be as stressful as riding wave to wave on Lake Michigan.
So like I said it is all relative. If you are going to spend money, it can be either life insurance or external steering, it's up to the individual!! Just my .02
Good luck, hope this helps..
Dick
Dick
Keep in mind that there are two types of hydraulic steering. You have FULL hydraulic from the helm, that does NOT utilize any cables. Then you have EXTERNAL hydraulic, that uses cables from the helm to the out drive and utilizes the hydraulic rams for external use only.
BIG price difference between the two! In my opinion, if you are running at speeds over 70, I would go with FULL hydraulic. I have heard the figure of 75 mph as the cut-off point also.
I don't see where the use of a full hyd. or an add-on should make a difference. They both remove the stress from the steering arm and put it to the outdrive itself. They both give the same added security that is needed. I've never heard of the steering arm breaking with the add-on systems. Which more likely fails.....the hyd lines and helm, or the cable. BTW, we ain't talking no 1/4" steel cable with pulleys. The cable only acts as a method of switching the valve, so not like it is under all the forces that is applied to the steering arm (tiller). The tiller is what is actually the conscern(weakest link) here, right?
Some people are like Slinkies - Not really good for anything, but they
bring a smile to your face when pushed down the stairs.
Charter Member #1492
I have the full package on my Donzi and I love it. It is really a stable package. The boat is a lot more comfortable to drive on the long hauls.
I agree the full hyd. is the cats meow. Was just trying to convey that any hyd. system would eliminate the slop and more importantly be safer.
Jerry
Jerry
Mercruiser recommends external steering for any boat using its products that run at speed greater than 70mph and tie-bars on all twin engine boats that hit speeds of 60mph or faster. With an external steering system, the full hydraulic is the way to go in my opinion. With full hydraulic the steering is smoother and more comfortable. You can actually take your hands off of the wheel in mid turn at high speed and the boat will stay exactly on course with the full hyddraulic. Race boats and the fastest pleasure boats use full hydraulic systems from IMCO, WPM, Marine Marine and Latham exclusively.
