Inflatables/RIBS
Has anyone done a significant amount of repair work to the tubes of one?
I recently picked up a 15' Novurania 550 and it has a slow leak. The old owner said it was likely a valve. After looking at the tube bottoms, they could use some work... I'm not convinced it just leaks from the valves... Specifically, I am thinking of picking up something called Tuff-Coat....Supposedly there is a base coat and a finish coat that is like a liquidized rubber and also a paint. Its $300-$400 bucks but thats better than $4k to get new tubes... Has anyone ever used it that can give some insight? Also, anyone know where to get the valves and how hard are they to replace? Thanks. |
These guys may be able to answer your question it is a UK based site as RIB's are very common in the UK their is also a USA section
http://www.rib.net/ |
| All times are GMT -5. The time now is 05:37 PM. |
