Amazing..!
Still no appropriate arch found for my 87 Scarab 38 kv MV edition. Lot of arches offered, but none that fit! Preferrable off a similar Scarab, already MV painted. C'mon guys, together we know so many people, it HAS to be out there! Cheers, seb
1 Attachment(s)
I have an arch off a 86 Cig flatdeck. I'm not sure it would work for you. It's white.
Thanks, I really appreciate your reply, but I need the arch set backwards.. Thanks again, cheers, seb
Originally Posted by Sebastian
(Post 2599084)
that's what I'm finding out right now...Hopefully that will work. Thanks..
1 Attachment(s)
"45Sonic" here on OSO has an arch for sale that was removed from a 45 Sonic.
The attaching studs go straight down from the bottom so mounting it should not be a problem either way it faces.
Ok, great! Do you have some measurements? cheers
At the bottom outside to outside is 6'-8 1/4" at the top it is 6'-1" and the width of the base is 1 3/4" by 1'-11 1/2" Long. It stands 3'-3" Tall.
| All times are GMT -5. The time now is 08:46 AM. |
