Trouble on 502 mpi engine , help wanted ! >
Old 07-07-2008, 01:12 PM
Default Trouble on 502 mpi engine , help wanted !
Hi , This moring I was sailing out of the harbor , arriving at sea I reved the engines and after cruising at 40 mp/h , abouth 1 or 2 minutes later , the starboard engine lost its power . When in neutral it would reve to 4.500 rpm , but I could hear that not all cilinders were workong , it sounded like a 4 cilinder.
Then i tried runninn a few minutes at 2.500 RPM on the other engine en opening the trottle a little more in the starboard engine , hoping it was only some dirty sparkplugs ?? but after 10 min. i gave up, it wouldend reven over 1200 rpm when in forward. So i checked the ecu for any DTC's (I have a small one with flashing led) and it showed code "12" so this means , no codes in ecu.
Oil pressure at 1200 rpm was 40psi , oil temp = OK , engine temp = OK too.
So far I have changed th espark-plugs , new cables , new rotor , new distributor cap , new ignition module in distrubutor , new fuel filter .......
So please help.............................
douglas_be is offline
Old 07-07-2008, 01:58 PM
Carbs or FI?
deltaAce is offline
Old 07-07-2008, 02:03 PM
Originally Posted by deltaAce
Carbs or FI?
Title of post says MPI so I'm guessing.....injected
MacGyver is offline
Old 07-07-2008, 02:27 PM
deltaAce is offline
Old 07-07-2008, 02:32 PM
Ted G's Avatar
You need to check fuel pressure at the small port on the fuel rail that looks like a tire valve.
Chesapeake Bay Powerboat Association
www.cbpba.com
Ted G is offline
Old 07-07-2008, 03:15 PM
sleeper_dave's Avatar
sounds like a fuel problem.
sleeper_dave is offline
27Fountain
Wanted
3
10-13-2008 10:28 AM
articfriends
Wanted
1
09-16-2008 08:31 PM
articfriends
Swap Shop
0
09-15-2008 12:42 AM
cloudmaster_321
11
08-03-2008 04:31 PM
jmackin
3
07-07-2002 09:19 PM
Quick Reply: Trouble on 502 mpi engine , help wanted !
