1.36 drive help
Old 07-15-2008, 06:56 AM
Default 1.36 drive help
Just found out I have 1.36 drive ratios on a pair of XZ ‘s. The problem is the boat, a 28’ Pantera, used to go 94MPH now it’s got 377 small blocks getting 4400 RPM with Bravo 1 22” props. Is it crazy to go down to a 19” prop( four blade) ? I guess it would help to go three blade to help get the RPM’s up , but on a heavy hull I always heard four blades work best. Any opinions??
Austin is offline
Old 07-15-2008, 07:01 AM
PatriYacht's Avatar
Sell them and buy a pair with 1.65 ratios. Slowing down the propeller speed is generally more efficient.
PatriYacht is offline
Old 07-15-2008, 09:04 AM
johnnyboatman's Avatar
swap gears,its not that hard, sell me the 136s
johnnyboatman is offline
Old 07-15-2008, 09:52 AM
Brad Zastrow's Avatar
Change the gears. You might find a pair you could swap and pay for labor only.
Brad Zastrow is offline
Old 07-15-2008, 11:16 AM
When you say swap gears does that mean upper and lower... or just the lower unit? Can you buy gears only and keep the current housings you have?
Austin is offline
Old 07-15-2008, 06:04 PM
Austin, you can swap gears and keep the original housing. Make sure whomever does the work is familiar with Bravo drives because the shimming of the gears is very important. Not a big deal to do on Bravos. You will really liven up that Pantera with 1.50 or 1.65 ratio. You will feel a big difference in accelleration. Good luck.
thedonz is offline
Full Force
Drives and Lower Units
3
10-15-2007 07:29 AM
Canada Jeff
10
07-19-2007 02:38 PM
thayes11
0
10-02-2005 12:36 PM
Velocity Tom
07-16-2003 10:13 AM
panteraracin
3
02-07-2002 10:36 PM
Quick Reply: 1.36 drive help
