1.36 drive help
Just found out I have 1.36 drive ratios on a pair of XZ ‘s. The problem is the boat, a 28’ Pantera, used to go 94MPH now it’s got 377 small blocks getting 4400 RPM with Bravo 1 22” props. Is it crazy to go down to a 19” prop( four blade) ? I guess it would help to go three blade to help get the RPM’s up , but on a heavy hull I always heard four blades work best. Any opinions??
Sell them and buy a pair with 1.65 ratios. Slowing down the propeller speed is generally more efficient.
swap gears,its not that hard, sell me the 136s
Change the gears. You might find a pair you could swap and pay for labor only.
When you say swap gears does that mean upper and lower... or just the lower unit? Can you buy gears only and keep the current housings you have?
Originally Posted by Austin
(Post 2623999)
