CMI header warranty questions!!!! >
Old 08-11-2008, 04:36 AM
Originally Posted by BillR
PLEASE stop w/ all the Active Thunder HYPE!!! I know you mean it in jest, but it is getting old!!
Thanks Macklin - we'll see what the verdict is.
Obviously I am not in a good mood! Headers pressure checked fine! So I have either a blown head gasket, cracked head or cracked block. Any ideas?
Boat is now in NC and in the hands of Joey Griffin. I hope the Heck it is a head gasket!!!
Sorry
formula 382 sr-1 is offline
Old 08-11-2008, 06:07 AM
Biggus's Avatar
I've seen the 575 SCI intake manifolds rotted pretty bad. I'd be looking there.
Good luck,
Kurt
Biggus is offline
Old 08-11-2008, 07:10 AM
OSO Moderator
BillR's Avatar
Good luck,
Kurt
If they were rotted, wouldn't ALL cylinders get water? I also had brand new ones installed when motors were rebuilt in '05. The mating surface of old ones was corroded a little.
Oh, and there is some water in oil. Noticed oil level was about 1 quart over full, still looked good though. But on the bottom of the oil fill caps on valve covers - milkshake!
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 08-11-2008, 09:36 AM
mwdill's Avatar
good luck Bill,
i hope it's only a head gasket also.
mwdill is offline
Old 08-11-2008, 09:44 AM
Forum Regulator
Sydwayz's Avatar
Bill, while one would assume only one problem; make sure you give the oil cooler a really good check as well.
Sydwayz is offline
Old 08-11-2008, 10:00 AM
blume's Avatar
There is a guy in Fort Lauderdale that repairs them, I thinks it's around $500.00??? That's what he charged a friend. I can get the name or number if you need it?
blume is offline
Old 08-11-2008, 02:32 PM
Ratickle's Avatar
Originally Posted by mwdill
good luck Bill,
I had the same problem, only worse. A head, Dart Iron Eagle, cracked in half sideways, less than 10 hours on a 540. When Dart was notified, they said it was an issue with marine engines and gave me two new aluminum Pro1's. Over $5,000 worth of damage and port work I was out of luck on.
Ratickle is offline
Old 08-11-2008, 03:09 PM
OSO Moderator
BillR's Avatar
1:30 pm
Motor is out of boat - crossing fingers for a simple / easy fix.
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 08-11-2008, 03:30 PM
seafordguy's Avatar
1:30 pm
Sorry to hear about your bad luck.
I assume you had planned to do the rendezvouz.....
seafordguy is offline
Old 08-11-2008, 04:09 PM
Geronimo36
Panther's Avatar
Dart did the same thing for my friend a couple years ago.....
Luckilly his engine just filled up with water and didn't wipe out any other parts...
Panther is offline
Quick Reply: CMI header warranty questions!!!!
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell or Share My Personal Information -
Copyright © 2023 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
