-   -   Skeg Repair?? (https://www.offshoreonly.com/forums/general-boating-discussion/193376-skeg-repair.html)
RunninHotRacing163.1 08-18-2008 10:04 AM
Originally Posted by Chris Sunkin (Post 2655955)
Skegs aren't just for straight-line stability. They see substantially more stress in turning. If you're OK with taking a chance on a spin or a barrel roll when a welded one snaps in a hard turn...
Bummer BIG Daddy & Ditto on what Chris said .. gotta have some big Kahunas to weld em up & run it again and cross your fingers
spazboz 08-18-2008 10:25 AM
I would have to agree with these guys on this one. At those speeds and taking into considderation the performance level of your boat, I wouldn't risk it either. If we were talking about a 1985 Sea-Ray wiith a top speed of 35 mph, I'd say weld it and go, but not with this one...
Roger 1 08-18-2008 10:59 AM
Originally Posted by Brad Zastrow (Post 2656123)
Frank just because a bravo I/O has had success with a welded skeg with boat that runs less than 70 mph does mean you should attempt a repair on high speed Skater with surfacing lower units. I can not stress how foolish that can be. I have broken more O/B parts than I care to think about including snapped off skegs at least four times on twin and triple setups and that was with good lower units. Once even lost the whole lower unit when the mid section broke. I was told by many people not to even think about welding a skeg. We threw them in the trash.
I could'nt agree more. I have repaired many skegs on lower performance lower units so it's not a question of if it "can'' be repaired or not. Nor is it a question of the weldors ability to preform the repair. Sometimes the wisdom to say ''no'' to doing a repair is more important that possesing the skill to do it.
If it is a ''surfacing'' drive or a drive being used in a high performance application, I won't touch it and advise the customer to replace it.
Roger
