Like Tree0Likes
Since I can't Get help on the Donzi Forum
Old 08-28-2008, 09:26 PM
Thanks for Serving!
The prop RPM difference is not surprising, I have found many prop oddities in my own boat.
Example I can spin 25 3 blade 5900 RPM
I also have a 26P 4 blade I can spin 6000. RPM and the boat is 1mph slower??? Doesn't make sense- but it is what it is.
As for your rig, low to mid 70's sounds about right.
Someone said earlier your mills may be getting tired - do a leakdown test and see what they are holding. With fresh blocks and some bblades worked props you may see 80.
Uncle Dave
Laveycraft 2750 Ilmor 710
Laveycraft 20.8 Sebring 406 SB
Fleetwod nitrous toy hauler
Yamaha raptor 700/Kawi KFX 450
Nissan Titan
Uncle Dave is offline
Old 08-28-2008, 09:52 PM
ZXXX Donzi's Avatar
My Boats: Fountain 35 w/500 EFI's, 1973 Donzi X-18 w/383 Mag,1974 Chris Craft Roamer w/1271TI's
Thanks for serving too!
From what I have heard Shang is right on the money. I have seen a few Scorps in persons. Nice looking boat.
ZXXX Donzi is offline
Old 08-31-2008, 06:21 PM
Wink How to get small blocks to go 80+
Sounds like you might need to change those iron small blocks over to a pair of our LSM550's and really see some real 80-90 mph speeds!
Regards,
Ray @ Raylar
Raylar is offline
Old 08-31-2008, 08:55 PM
My Boats: 99' AT28twin, 2004 Starcraft, 1978 Switzer
Quote:
Regards,
Ray @ Raylar
Don't you mean 90-92+??
spilman is offline
Old 09-01-2008, 11:04 AM
My Boats: 12' toon w/ a 24 volt 80lb Minn Kota
Go to Donzi.net and PM "Mr X". I don't recall what his was running but I know for sure he walked away from me at 76 mph Ted knows Donzi's in and out and will get you pointed in the right direction.
Dan
p729lws is offline
Old 09-01-2008, 06:57 PM
Wink
Might make 88-90mph, I am not so sure that hull would see 92mph even with 1400 hp.!
Best Regards,
Ray @ Raylar
Raylar is offline
Old 09-01-2008, 07:03 PM
ZXXX Donzi's Avatar
Best Regards,
Ray @ Raylar
Oh it would and has seen 90+ with Procharged 350 mags (ok so they were also worked over).
My 26 has a pretty similar running surface and it runs in the 90's and does it with authority. But hey, its a single.
Old 09-01-2008, 07:24 PM
Registered User
Shanghied Again's Avatar
My Boats: Shanghied! 2004 Donzi 33 ZX
You are correct your 26ZX has the same running surface but the big difference is one engine verses 2. The 26ZX will un with big power the boat is made for one engine big block. The 28ZX runs 2 small blocks weight to hull ratio. Big blocks will not work in a 28ZX to dangerous.
Shanghied Again is offline
Old 09-01-2008, 08:40 PM
ZXXX Donzi's Avatar
Quote:
I could see that weight being a pretty big difference. I could also see the big blocks being a very bad idea.
I would like to see some more folks do stuff to the twin ZX. I think that some cool things could be done. A couple of Ray's light screamers might be the ticket. That would be a strong package that you could beat on pretty good. If I had to run in rough water I would have looked pretty hard into that idea.
Old 09-06-2008, 09:37 AM
Scott B's Avatar
My Boats: Donzi Criterion SS, X-18 , 16 OB, Z-235, F-14, Magnum Missile
Quote:
Originally Posted by sellsman11 View Post
In order to see 82 in a 28ZX with Scorpions, you will need to put the boat back on the trailer. Hook it up to a FAST truck and FLOOR IT!!!!
I think 72-75 is about the top end of that boat.
At least until you learn how to drive... Baby steps man, baby steps...
Scott B is offline
LiveWire
04-09-2012 07:21 PM
dave911
03-15-2008 04:30 PM
otis311
LGPBA
2
11-26-2007 08:25 PM
cfischer
04-26-2006 11:51 AM
MYPANTER24
Pantera
4
10-16-2002 08:28 AM
