-   -   KPM Water Pump Parts (https://www.offshoreonly.com/forums/general-boating-discussion/194634-kpm-water-pump-parts.html)
StrikinLightnin 09-04-2008 04:16 PM
Looking for "o" rings and impellers to rebuild pumps.
I there a US dealer?
I want to take a look and see what the impeller looks like after one season.
Boatlesss 09-04-2008 07:15 PM
you can always get or make an o ring i am pretty sure they used a globe rubber works blue impeller so you can source the parts in the us no problem
StrikinLightnin 09-05-2008 07:20 AM
No blue impeller in it as I had it apart when I purchase them.
It's their own impeller but the Merc will also work in it.
I had to drill out the pump body so it would work with the external fuel pump setup.
Yeah I could make an o ring but don't want to if I don't have to.
LubeJobs42 09-05-2008 08:24 AM
Hi, If you email Jules at [email protected]
He just rebuilt mine, they came back beautiful.
StrikinLightnin 09-05-2008 11:47 AM
Thank you,
Dennis
aTX427 09-06-2008 07:17 AM
That was a false statement I was told by the original US distributer. KPM uses the standard Merc impellor. Jules at [email protected] was always very responsive to me.
StrikinLightnin 09-06-2008 07:48 AM
Just passing on what I was also told years ago.
Maybe it is really just a Merc impeller.
If it is then why is it supposed to be able to run dry?
RunninHotRacing163.1 09-06-2008 08:17 AM
Hey BIG daddy use the merc impellers, you'll notice a difference in water pressure if you use the Sierras and you'll be changin them again :ernaehrung004:
RunninHotRacing163.1 09-06-2008 08:20 AM
able to run dry:eek: may as well order 4 extra impellers now
cause run dry aint gonna work:ernaehrung004:
StrikinLightnin 09-06-2008 08:37 AM
You're not kidding.
Had enough adventures with impellers without trying to run them dry..........:drink:
