240 Sport.....
Hey Jeff, I was with Jimmy the other day and we got some PARTS for you. If you need a hand I`d like to help. I`ve played with this kind of stuff for years and I might be able to give you some help and advice.
Kurt. |
Kurt, Looks like we are going to have to repower, that 454 thats in the baja it is a 2 bolt bluewater block with all cast internals and i am not going to spend the money on that block to switch to forged parts. I think i saw in one of your post that you had bought a couple of motors from 1800runsnew. in Mass i am considering buying there 502/502 HO did you have good luck with there engines? any info would be helpful, and yes if you want to come over and lend a hand you are more then welcome i will be up to jimmys shop the week of 3/18 to start tearing it down as long as i have a motor by then. Jim is still trying to hunt down a Bravo 1 transom assembley for me. Talk to you soon, Jeff
Hi Jeff, I had great results with 1800 runsnew although the 502/502 might not work too well considering the application. The cam will be wrong for a blower application and you really should have a set of heads made up for that application also. The valves in those motors are 2 piece and you WILL drop a valve. Go with Manley severe duty stainless intake and Inconel exhaust valves. Look up Jeff Cox, Jimmy knows him, in Windham, He can build you a set of heads for reasonable money.
Another avenue to check out might be to buy a 502/502 shortblock and install your own cam and heads. Call me if I can be of help, Kurt 207-693-4911 |
240 sport
what's the plan for the 2 bolt that's in there. is it running? |
Rambunctious, The motor is fine it only has about 20 hrs on it, its for sale it has a holly 850 and it pushed my 240 sport at 56 mph just looking for more speed. Thanks, Jeff
| All times are GMT -5. The time now is 11:08 PM. |
