Like Tree0Likes
Anyone know Trailering capacity for 2003 Z71 Avalanch
Old 10-09-2008, 02:47 PM
Registered User
BAJA WILL's Avatar
My Boats: Don't even mention the word boat
Default Anyone know Trailering capacity for 2003 Z71 Avalanch
Looking at picking one up cheap but need to know if it can pull boats??
WILL
BAJA WILL is offline
Old 10-09-2008, 02:55 PM
NASCAT's Avatar
My Boats: 2017 Nor-Tech 340
It Depends On Whether It Is 2wd Or 4wd, What Gear & Or Whether It's A 2500 Model. I Want To Believe They Were Around 7200lbs Towuing Capacity. My '08 Has An 8000lb Capacity W/ A 4.11 Gear.
NASCAT is offline
Old 10-09-2008, 03:17 PM
Knot 4 Me's Avatar
My Boats: Old/Heavy/Slow
I had an '03 1500 4WD Z71 Avalanche with the 5.3L and 3.73 gears. Towing capacity was right around 7K if memory serves. It was no towing beast...
Knot 4 Me is offline
Old 10-09-2008, 03:33 PM
i didnt know you could get an 08 with 8000lb and the 4.11's. I tried to buy an 08 avalanche 2500 and they said the no longer make them, the best they could come up with for an avalanche was 7200lbs. I ended up buying a tahoe which can also tow 7200lbs, figured either way i was screwed for towing my clam
Boomer35 is offline
Old 10-09-2008, 03:38 PM
Registered User
BAJA WILL's Avatar
OK, 5.3 motor,
Are all Z71 packages 4X4????????
Old 10-09-2008, 03:47 PM
NASCAT's Avatar
Quote:
B35
You are correct, 2500 3/4 ton option no longer available. Only options are 5.3L vs. 6.0L, 2wd vs. 4wd & 3.73 vs. 4.10 (not 4.11).
I've been towing my 30 Skater locally to the ramp (approx) 6 miles figuring if the boat weighed 6700lbs dry the boat & trailer might weigh 8500lbs. I was way off. I towed to a truck stop & dropped the boat & trailer on the scales, much to my surprise she weighed out @ 10,950 1/2 full of fuel. The auto leveling suspension is deceiving as I'm way over. Ordered a 6.0 gas 2500HD Crew Cab w/ 6spd auto w/ 3.73's.
I believe wheelbase & LT tires make the biggest towing difference from a weight handling standpoint. Tahoe has a pretty short WB, an Avalanche is equal to a Suburban (which is still available in a 3/4 ton).
NASCAT is offline
Old 10-09-2008, 03:49 PM
NASCAT's Avatar
Quote:
Originally Posted by BAJA WILL View Post
OK, 5.3 motor,
Almost positive! I believe the offroad package for a 2wd is Z77
NASCAT is offline
Old 10-09-2008, 04:03 PM
Trade Score: (1)
My Boats: 31 Resin bucket
http://www.offshoreonly.com/forums/s...d.php?t=178518
Open72 is offline
Old 10-09-2008, 04:41 PM
Forum Regulator
Trade Score: (1)
Sydwayz's Avatar
My Boats: 17' Speedliner Cat & O.P.B.
Z71 is a 4x4
Z66 is 2WD
3.73 or 4.10 rear end is most important factor
2500 Avalanche was discontinued in 2004 I believe.
There is no such thing as a Z71 2500 Avalanche.
Sydwayz is offline
Old 10-09-2008, 04:48 PM
NASCAT's Avatar
Quote:
Originally Posted by Sydwayz View Post
Z71 is a 4x4
Z66 is 2WD
Sydwayz has got all the facts. I said Z77 when I meant Z66, I just couldn't picture it in my head. Those are pretty rare in the southeast!
NASCAT is offline
johnny g
33
08-31-2007 10:26 PM
10x
38
03-30-2007 11:08 AM
wwwTOPDJcom
03-31-2004 05:12 PM
wwwTOPDJcom
03-30-2004 09:48 PM
Tantrum
12-18-2002 10:21 AM
