Trim Tabs
Ok, so I'm wondering what everyone thinks about this. How often do you actually use your trim tab indicators and would it be worth getting a system with this feature? I've been looking around and think I'm going to go with a Lenco system, but I have to decide if I want the tab indicator switch or not.
Also, before I go and buy these, does anyone have tabs they would like to sell? These are the tabs I was considering, so something comparable to these would be great if I could find some used ones at a good price. Thanks! http://www.lencomarine.com/highperformancet.html |
1 Attachment(s)
I got these that I'm getting ready to take off my boat. They are complete with pump and lines. I'm putting 280 K-Planes on so these will most likely end up on ebay. $125 shipped to your door if you want them.
I'd like to stay away from the bennets. I had the same on another boat I had and was not impressed with them whatsoever. They were very very slow reaction time. It took about 10 seconds to move them from full up to full down. Thanks anyway!
A friend of mine bought a set of Lenco's for a 21 Scarab. I can't say I was impressed with the quality of the construction. He wasn't either and returned them before installing them. He wound up with a set of Bennet's and was very happy with them. If your looking for real offshore tabs, the keikhaefer's can't be beat by much.
BTW that is a GREAT price on those used tabs! |
No problem...you want what you want. I'm the same way. If anybody wants them let me know.
Originally Posted by 89Mach1
(Post 2745211)
Sorry, I've had K planes on my last two boats. 280 and 380. Love em. I had Bennets on the boat before that, but I don't remember them being that slow. |
2 Attachment(s)
I had bennetts and also had insta trim,never used them,way to slow,took for ever for them to move.
I installed a set of Lenco hi perf 14x19 dual cyl tabs,are they Kplaines?no,but they are great tabs,fast acting,I find my self using them all the time. as far as the switch,you can use a dubble pole/dobble throw rocker switch.and go with a mechanical indicator,thats what I did and they work great. |
Originally Posted by boatnt
(Post 2745254)
I installed a set of Lenco hi perf 14x19 dual cyl tabs,are they Kplaines?no,but they are great tabs,fast acting,I find my self using them all the time. as far as the switch,you can use a dubble pole/dobble throw rocker switch.and go with a mechanical indicator,thats what I did and they work great. Those look great, where did you get them from? How long have you had them and any problems with them? Do you use your indicators often or just go by feel most of the time? I'm starting to think I should start off without the indicators and if I feel as though I need or want them I can always add the mechanical one later. How was the install? Thanks! |
Originally Posted by Macklin
(Post 2745250)
10 seconds? What are you looking for...rocket tabs? :rolleyes:
My Bennetts are 8 seconds from full up to full down. 4 seconds from full up to neutral. I dont think you would want them much faster. The boat does take a second to react to the changes and you dont want to go too far too fast. Slow change figure out what you need then continue adjusting. Just my thought.
Originally Posted by jdub
(Post 2745230)
Originally Posted by heavyhauler
(Post 2745683)
Sent you a pm.
89mach1...check these out. I don't know if it's a deal or not. Not sure what new ones go for. Might be something you could use though.
http://cgi.ebay.com/New-25-X-14-Lenc...QQcmdZViewItem |
89Mach1-
Just my two cents from the peanut gallery- Since you just recently picked up that ride I would take care of the cosmetic upgrades you wanted to do along with any safety or maintenance items (if there are any) and then just run the boat as is. Those are pretty well balanced boats and you might decide tabs aren't even needed. My boat is a pretty similar hull and I've only wished it had tabs once or twice in ten years.. I'd run it for a while and then decide what needs upgrading.. Nice looking boat- hope you enjoy it :drink: |
(Post 2745715)
http://cgi.ebay.com/New-25-X-14-Lenc...QQcmdZViewItem Thanks! I have them in my watch list. New I think they are about 1300 or so, but I'll keep an eye on them. Thanks for the heads up! |
(Post 2745766)
Give King Marine a call. 856-582-5222 in New Jersey. I looked into them before and they said they could get them for me for $1100.00.
Trim Switches on Steering Wheel
This is kinda related, has anyone used trim switches that are mounted on the steering wheel? I like to adjust my tabs when conditions change when either going WOT or in the rough. I just don't like taking my hands off the wheel to adjust the tabs. I saw some Dana Marine Steering Wheel mounted switches and I like the idea, just wondering if anyone has any experience in using them.
thanx |
I have a complete Insta-Trim 16" dual ram system available. Excellent condition, I must be less than an hour drive from you.
Will sell cheap to get it out of the garage. |
| All times are GMT -5. The time now is 04:14 PM. |
