-   -   Bravo XY, go thru or keep going? (https://www.offshoreonly.com/forums/general-boating-discussion/199319-bravo-xy-go-thru-keep-going.html)
Turbojack 11-24-2008 06:00 PM
My Bravo XY outdrive now has 335 hrs on it. Do I have the drive gone thru or just change the lube and keep going?
I change the drive oil aprox. every 25 hrs or less. I do not run hard except every once and a while. I take off easy most of the times. There is very little fillings if any on the magnets of the drain plugs every time the oil is changed. I pulled the top cap and looked at the gears, from what I can see they look great.
I think I am going to have the drive gone thru and then I remember reading about all of the drives that have been gone thru and torn up shortly after they have been rebuilt.
If I have it gone thru who does the best in the Houston / Austin area?
bigboat28 11-24-2008 06:13 PM
How much does it cost to go through a drive?
