Fuel pumps
I am dumping my 7.4 MPI's and building 496's with edelbrock heads, eagle bottom ends, Crane 731/741, victor intakes, 950 carbs. Do I have a designated fuel pump for each motor or use a central pump for both? How do I know how much flow I need from the pump(s)?
One motor one pump. Plus add a fuel pressure gauge for each engine.:ernaehrung004:
Originally Posted by Jeff P31
(Post 2788232)
If you run 3\8 fuel lines at 6 or 7 psi life will be good.:ernaehrung004:
sorry maybe I wasn't clear---can I use Holley blues? Need bigger? What kind of GPH?
I'm sure that holley blue's will work just fine with reg's.
I hadn't thought about it but could I use the pumps from the 7.4's?
Originally Posted by wet_rat
(Post 2788291)
You could, you would just need a regulator to keep it at 7 psi. Darrell. |
3 Attachment(s)
Holley blue pumps should be enough for what you are building. Just make sure you use a large filter/water seperator and 1/2" lines. Also, make sure the pickup in the tank is large enough. I have seen so many boats with a little piece of crap plastic pickup. No matter how big a pump you put, if the pickup is to small, it won't work. Do not assume the pickup is big enough. Take it out and have a look. I build my own from SS tubing and fittings. Here is a pic of a factory one in a Donzi and the replacement that I built.
that looks great! I will pull mine and check them. thank you
so that example would be 7 PSI ???
Originally Posted by Jb-fse
(Post 2788502)
Here is a little info to help you to size a fuel pump.
horse power x.5#s = pounds of fuel per hour. pounds per hour -: 60 = gallons per hour. gph -: 6= gpm. here is a example . 500hp x.5=250#s 250# -: 60= 4.16 gph 4.16gph -: 6=.69 gpm at what psi you want to run at. if you have any questions I can help you with feel free to call we are a Sx-performance fuel pump dealer. 586-790-8880 ext 251 |
let me correct myself
fuel pump size.
typically at wide open throttle , full power, an engine requires 0.5 lbs of fuel per hp every hour. a gallon of gas weights approximately 6.0 lbs. exp. 500hp x .5=250lbs per hour 250lbs per hour-:- 6.0=41.66 gallons per hour 41.66gph -:- 60=.69 gpm sorry for the confusion (bad day) |
| All times are GMT -5. The time now is 09:01 AM. |
