-   -   Survey- Bravo x drive reliability?? (https://www.offshoreonly.com/forums/general-boating-discussion/20380-survey-bravo-x-drive-reliability.html)
Cattitude 03-18-2002 11:52 AM
Cobra Marty had a great thread last year on Bravo's failures and factors. Many of us now have or are considering x drives (x,xz or xr) in the future. It would be great to hear from those who have accumulated some hours on these drives and learn how they are doing. If I remember right there were some reports of gimbal hsg failures and also short lives when pushing a heavy boat. I believe Goodfella @ Dollar even reported the xz upper gears holding up better in the factory racers. For those of you with some hours, please report what you can:
Which drive?
still alive?
hrs on drives?
hp/tq?
single/twin/triple?
prop pitch/gear ratio?
showered?
length/wt of boat?
v or cat?
internal inspections and results?
lube used?
gentle/ average or madman on the sticks?
frequent air time?
Thanks for your help!
Turbojack 03-18-2002 12:45 PM
Which drive? XZ
still alive? No problems to date
hrs on drives? 50+
hp/tq? 600+ twin turbo
single/twin/triple? S
prop pitch/gear ratio? 30 bravo 1, 1.36
showered? Yes
length/wt of boa t? 26',
v or cat? Cat, 2001 daytona 26
internal inspections and results? not yet
lube used? stock
gentle/ average or madman on the sticks? gentle to average
frequent air time? maybe 3 times
SCARABJ 03-18-2002 04:18 PM
Which drive? xz uppers/ imco 2 inch shorter lowers
still alive? yes
hrs on drives? 35
hp/tq? 725 hp 509 eickerts w/prochargers
single/twin/triple? 2
prop pitch/gear ratio? 30 1.36 97 radar
showered? yes
length/wt of boat? 32 8500
v or cat? v
lube used? merc high performance
frequent air time? very little
went with xzs because the gear 1.36
Cattitude 03-19-2002 06:06 PM
TTT
TTT- I know there are people out there with some hours on these- tell your story!
SteveDavid 03-19-2002 06:46 PM
XR drives
no failures, yet :) or possibly :(.........
Triple 700(s) supercharged (Whipples) 500 EFI's
showered
Vee bottom, step, notch, extension box
boat weight app. 13,500 pounds
1.36 ratio
31 pitch Hydromotive 5 blades
length 43'
gentle on the throttles
app. 100 hours run time
Merc. green gear lube
Taken off and lubed at 50 hours, everything OK, and again at 100 hours all OK except Pinion seal shot on Port outside drive (Apparently common problem on XR drives) When this goes, it leaks drive fluid into the bellows and then the bilge.
Air time, some, most trips are lengthy to Bahamas or Keys.
Garry 03-19-2002 09:57 PM
Which drive?
XZ
still alive? Yes
hrs on drives? 65
hp/tq? 700 HP500 whippled
single/twin/triple? s
prop pitch/gear ratio? 1.5 labbed 32
showered? y
length/wt of boat? 27 4300lbs.
v or cat? cat
internal inspections and results? small shavings at break in and minmal shavings at 40 hr lube change.
lube used? merc grn.
gentle/ average or madman on the sticks? average
frequent air time? little air.
Steve ..
Did you get the 31s from Gary yet?
Uncle Toys 03-20-2002 10:53 AM
Sorry Cattitude, I don't have anything to add - only Bravo Ones. But at least I can get your worthy thread back to the top.
Brad 03-20-2002 11:49 AM
Which drive? XR
still alive? Yes
hrs on drives? 135
hp/tq? 500 EFI's
single/twin/triple?Twin
prop pitch/gear ratio? 30 1.5
showered? Intercooled at 120 hours
length/wt of boat? 35 Cig 8,300
v or cat? V
internal inspections and results? Good
lube used? Mercury & Royla Purple
gentle/ average or madman on the sticks? Average
frequent air time 25 % Ocean rest on small lake.
Did have a problem with seals at 100 hours as Steve described.
sterndrivespec 03-20-2002 11:58 AM
XR drives
37 profile
twin 600 hp blower motors
50+hours
mostly in poker runs
the uppers were new,the lowers had 90+ hours on them with 900 hp,everything still like new
Cattitude 03-21-2002 01:16 PM
ttt
ttt
