-   -   where to find stainless braided trim lines???? (https://www.offshoreonly.com/forums/general-boating-discussion/205971-where-find-stainless-braided-trim-lines.html)
302Sport 04-01-2009 08:06 AM
I am looking for a stainless braided trim line for a TRS set-up, and was wondering where I should be looking for one???? Mine has a pinhole in it and leaks down, so I have the fittings and everything. I am going to call around locally today and see if somebody could make one up, but I was figuring you guys would know who would have one.
Hot Stepper 04-01-2009 08:14 AM
Good luck, I changed a set of lines last year. first set the morrons didn't use marine grade fittings. So then I ordered a set of fittings and hose from the manufacture but they were not assembled. Then I find that all the local shops only work with specific brands. So check your fittings for the brand then do a search for a distributor near by that hopfully can help you out. Cause the other isssue i ran into is they said they were not suppose to assemble anny hoses unless the parts came thru them
Jb-fse 04-01-2009 09:55 AM
Trim Lines
let me know what they are we make them all the time.
302Sport 04-01-2009 10:10 AM
theyre small maybe 5/16" and about 8ft long with one 45 and one 90 degree fitting on the ends......i just dropped them off at a place that said they might be able to do it, but what would you ballpark the price at, i dont want them to hose me..........
C_Spray 04-01-2009 10:19 AM
Many hydraulics shops will carry the exact Mercury-approved hose and fittings. Check around. Don't forget to make sure they clock the fitting correctly, since you don't have a straight fitting on either end...
Biggus 04-01-2009 11:24 AM
[QUOTE=C_Spray;2833888 Don't forget to make sure they clock the fitting correctly, since you don't have a straight fitting on either end...[/QUOTE]
Very good tip Chuck!:ernaehrung004:
CPPerformance 04-01-2009 12:04 PM
Give Mike a call over here and he should be able to take care of you.
:ernaehrung004:
800-225-9871
lightspeed 04-01-2009 01:56 PM
Moreland Hose ..Oakdale NY Ask For Billy
fantastixvoyage 04-01-2009 03:45 PM
Fluid Systems here in michigan can handle providing every last component needed up to and including the helm. Very helpful crew.
tomtbone1993 04-01-2009 04:10 PM
I got mine from Teague
