speedo not working
Any ideas how to try and fix? bravo ones.
Usually there is a rubber hose that popped off. Take a look around your drive.
The speedo pick up on the leading edge of the lower unit is probably plugged. Its a little notch about 4" above the bullet. The actual pick up tube could be connected to either drive.
That was always my problem. Take the smallest drill bit you have and start w that. prob some wood in there.
LEAVE IT PLUGGED, MAKES THE BOAT FASTER:party-smiley-004:
Originally Posted by brian18330
(Post 2838103)
I agree with griff. Proabably some wood in the pitote hole.
Speedo is fine...you just need more power:boat:
My speedo didn't work for me either....
So I switched to boxers:evilb: |
