Eureka !!!! Wellcraft Came Thru Finally
I have to share this with you guys, Finally someone at Genmar which is Wellcraft in Michigan, found out my long awaited answer: What drive and props was originally on my boat before the theft
2001 Wellcraft Excalibur 23 engine : 7.4L MPI 310HP Weight : 3800 pounds Drive : B3 Ratio: 2:1 Props pitch 25 !!!!!!! Now .... My GPS speed is 55-57 mph at 4300 RPM My holeshot is terrific with that setup so I can afford to loose a bit to get more top end my max RPM is 4680, That's all I have So what are you suggestion for prop size? Bravo 3 lab finish? 25 cupped? 26 or more? Thanks guys |
Originally Posted by maxfred8
(Post 2839255)
uh- I hate to be the one to tell you this but the standard B3 props come in even pitch sizes. Of course it is possible they were custom.
http://www.mercruiserparts.com/Selec...=Bravo%20Three Actually now that I run your numbers that is not possible, are you sure you have a Bravo 3? The numbers work with a Bravo 1 & a 23" at that speed. Most of those boats came with a 1.5 B1. http://www.go-fast.com/Prop_Slip_Calculator.htm |
| All times are GMT -5. The time now is 08:49 AM. |
