-   -   bbc 598 (https://www.offshoreonly.com/forums/general-boating-discussion/206783-bbc-598-a.html)
joepequa 04-12-2009 08:56 PM
bbc 598
any ideas on spark plug type and heat range got 598 ci single dominators in 38 top gun ant sug thanks
DareDevil 04-12-2009 09:25 PM
NGK br 6 fs
MER Performance 04-12-2009 09:52 PM
How about the type heads you have and comp.ratio probably alum. with a crush washer type plug and a flat top piston or inverted dome you can start with a R5673A-8 this is an NGK I use this plug on all my SC and natural engines and is safe to start with as long as you are not trying to cover up a problem with A/F ratio or idle problems. 92 octane and timing about 35 degrees btdc.
