Any lift truck mechanics on board?
This is kind of boat related, we use the lift truck to move the boat. Is OK right?
We are just finishing up a brake job on our 9000lb Mitsubishi & I have a question about adjusting the wheel bearings. In my experience (which is limited to regular automotive and trailer stuff) the bearings are tightened (by hand) to seat them, spin the wheel a few times, tighten again and then back off to zero pre-load or slightly further as needed to align cotter pin(or other lock device). Is this the same with the larger full-float axles or do the bearings actually get some pre-load? |
Originally Posted by Mbam
(Post 2845565)
We are just finishing up a brake job on our 9000lb Mitsubishi & I have a question about adjusting the wheel bearings. In my experience (which is limited to regular automotive and trailer stuff) the bearings are tightened (by hand) to seat them, spin the wheel a few times, tighten again and then back off to zero pre-load or slightly further as needed to align cotter pin(or other lock device). Is this the same with the larger full-float axles or do the bearings actually get some pre-load? Witha heavy drum like that it's important to torque to about 50ft/lbs while rotating, then back it off and set as you describe. This centers and seats the bearings. This is true for just about any kind |
Marc,
We're a Toyota forklift dealer, but, I do have a repair manual that covers certain Mitsubishi forklifts ranging from 2000-8000# capacity. It says to tighten the nut to 101 ft/lbs, back the nut off 80* rotate the drum and check the preload....preload is 4.7-7.6 ft/lbs. I would think your unit should be close to what this requires. |
That is great, kind of what I expected. I'll go with that.
BIG THANKS to both of you!! |
