565 CI carbed = 784 HP
Valako Race Heads
Jim should be proud of this one. http://www.youtube.com/watch?v=KA0a6KBp-CE http://www.youtube.com/watch?v=tOPeG1PxpZM&NR=1 http://www.youtube.com/watch?v=e_8c5...eature=channel Jim doesn't belong to this board however he certainly deserves a little credit. |
Hey John, Is that your motor ?? Either way great numbers !!
nice work guys, mind sharing your comp ratio, and lift?
The torque # was what I thought was very impressive. With his magic he worked on the floors of those heads I think he said he gained 40-50 lb-ft over his 565 (and used allot of welding rod). I think it was around 720lb-ft.? Not to bad for a 565NA.
I am going to talk to him tomorrow, I will see if he will post the specs on his engine or this engine. They are identical except his is fuel injected, versus carbed, and he welded the floors up on this carbed engine. He might be tearing the heads off his Fountain as we speak to weld up the floors and re-port. Its all in the porting ;) |
Originally Posted by getrdunn
(Post 2847852)
Valako Race Heads
Jim should be proud of this one. Jim doesn't belong to this board however he certainly deserves a little credit. His screen name is Jim V. He is the head flow guru. |
Hey Rookie,
Be sure and get on his s**t for taking a vacation is FL. He was just leaving to return home when I talked to him the other day. He drove all the way down for just a 2-day drunk. I can't believe his fountain is still in one piece. When you talk to him tell him I hope he gets to my heads soon. Jim is a all around great guy and has the ability to find and make power like none others. Imagine Jim and Bob under the same roof... Wouldn't that be miracle. |
nice job i think i heard a exhaust leak fools you somtimes thinking its lash noise good luck
Originally Posted by skaterdave
(Post 2847931)
(Post 2848042)
That sucks about the reverse deal. I heard about that. He menitoned the duration was 236/244 and the lift he thought was near .670. I like the end of the 27 ride video. Looked like he had his hands full didn't it.
(Post 2848778)
(Post 2847852)
Valako Race Heads
Jim should be proud of this one. Jim doesn't belong to this board however he certainly deserves a little credit. "JimV" is a member here and for many years---he just doesn't post as much as he used to. If there is anyone who can get the most out of a set of heads it is JimV. |
i was wondering on the lift. i'm running 565 dart blocks w/ brodix CNC heads, 8.5 to 1 and 720 lift solid roller. single holley 1050 and ran 750 hp and 710 torque on the dyno.
Hey guy's thanks for the nice comments. The engine was dynoed at Tom Earharts (thanks again for the help). Cam specs 236/244 .646/.651. Here's the results
rpm..........CT...............CHP 2000........616...............235 2500........630...............300 3000........659...............376 3500........657...............438 4000........725...............552 4500........757...............649 5000........765...............728 5500........746...............781 5750........716...............784 6000........671...............767 I will be pulling my heads off to remodify the intakes. This motor made an average of 39.9 ft lbs more torque thru out the curve with peak of 74 ft lbs @4000 rpm. :) |
(Post 2848875)
Thanks for sharing |
| All times are GMT -5. The time now is 10:12 PM. |
