Lunati Cam "check it out"
I realize Bob is the Cam Man however I must have missed this one with earlier cam searches. Let me know your thoughts. Exhaust is gils with high risers. Reversion???
Voodoo Retro Fit Hyd Roller Cam - Chevrolet Big Block 282/290 Product Description Lunati's Voodoo series of Hydraulic Roller camshafts deliver more area under the curve than any other series of Hydraulic camshafts. This means more throttle response, quicker acceleration, more vacuum, better efficiency, combined with maximum horsepower and torque! Hydraulic roller, lopey idle. High performance street cam. Likes upgraded intake, carburetor and exhaust system. Needs 2800 RPM or better stall speed converter, 9.75:1 compression ratio and 3.55-3.73 rear gears. Advertised Duration (Int/Exh): 282/290 Duration @ .050 (Int/Exh): 231/239 Gross Valve Lift (Int/Exh): .600/.600 LSA/ICL: 110/106 Valve Lash (Int/Exh): Hyd/Hyd RPM Range: 2200-5800 Includes: Cam Only Part Number: 60212 Jobber Price: $337.00 Cam Spec Card Print 60212 VDBC-282 CHEVROLET 396-454 2200-5800 110 5.5 9.5 53.5 41.5 106 4 .600 .600 1.7 1.7 .000 .000 N/A 231 239 282 290 http://www.lunatipower.com/Product.aspx?id=2156&gid=289 |
The LSA and ICL are not close to what you need in my opinion. Bob will design a cam for your needs, have it ground and shipped to your door for the same money.That you don't waste your time and money.
