-   -   Need BRAVO 1 HELP ASAP!! (https://www.offshoreonly.com/forums/general-boating-discussion/207457-need-bravo-1-help-asap.html)
bert4332 04-22-2009 09:48 PM
I took my boat out and docked it at the local marina, replaced my bunks and brought her back, when we pulled her out and reached the top of the ramp I hopped out to put on the tow straps and noticed that my drive was only halfway up. I tried unsuccessfully on several occasions both on land and putting her back in water, with the motor running, and not, the drive will only go half-way up and is just stops. The drive pump just quits like there is a kill switch, it works perfectly up to that point. I had to leave the boat at the dock parking lot, I cannot get it up the slightest hill and there are several.
1) Is there a way to release the drive and then lock-it in the up posistion?
2) WTF is going on?
thanx
DareDevil 04-22-2009 09:53 PM
2) WTF is going on?
thanx
U need to push the trailer tillt switch !!!!
It should be near the regular trim switch .:ernaehrung004:
No worries nothing wrong with the drive .
tms1155 04-22-2009 09:55 PM
Try the trailer switch
bert4332 04-22-2009 09:58 PM
I tried the both the trim switch and the trailer switch neither worked.
FlyinZX14 04-22-2009 10:23 PM
limit switch out of whack?
Plus you can still jump the trim solenoid and run it up the rest of the way if it is the switches acting up.
bert4332 04-22-2009 10:36 PM
I swapped out the fuse, it was a bad fuse! As soon as I put the other fuse in, the trailer switch worked.
thanx for the replies
21eagle 04-23-2009 04:34 AM
easy fix
now what an easy fix huh why cant it always be that simple chris
RHC 04-23-2009 07:53 AM
I can't seem to find the fuse in my bravo ! :drink:
RHC
bert4332 04-23-2009 10:47 AM
RHC
I can show you were it is, just hop in the water, hold your breath, it's right next to the prop, you can't get to it till the RPMs hit 4000! :evilb:
