Prop size for 600HP
Please only been there done that suggestions…………………………………
………… Ok I need a starting point. 23' Wellcraft Nova don’t have any Idea on what prop to start out with This is what I have 4000# deep V cuddy hull with a DYNO 502 640HP at 5800 and 624TQ at 5000 without accessories. Bravo 1 with 1.5 ratio. I ask Throttle Up they had no suggestion on props they only do CNC props. Therefore, do I want 3, 4, 5 blades, what hub…what pitch and labbed or not and what brand? |
Probably not too many people with that exact combo. You might want to call Brett at BBlades.
If it were me, I'd start with a stock Bravo 1 26P 4 blade; and have a 28P on hand. What prop did you have on the boat before upgrades? 3/4 blade? |
As I stated you want high rake props, like a Bravo I . If your drive height is original then 3B or 4B props will be the ticket. Your drives need to be pretty high to run 5B props.
Julie |
Originally Posted by Sydwayz
(Post 2856053)
If it were me, I'd start with a stock Bravo 1 26P 4 blade; and have a 28P on hand. What prop did you have on the boat before upgrades? 3/4 blade? I have a 3b 25 Mirage that cam with the Bravo 1. I don’t want to go out spin over the 5800 + to max rpm to find out I don’t have enough prop. Which some non-experts say I will be 6000 + on the Rpm with the 25" prop. |
Originally Posted by goebel1
(Post 2856105)
It was a basket case no prop and a 290 HP small block
A 28 pitch Bravo 1 would be a good starting point. Use BBlades test program.
Originally Posted by Fountain38SC
(Post 2856112)
So why not throw the 25 on it and see what happens?? It would give you a good starting point.
Originally Posted by Griff
(Post 2856127)
(Post 2856105)
I have a 3b 25 Mirage that cam with the Bravo 1. I don’t want to go out spin over the 5800 + to max rpm to find out I don’t have enough prop. Which some non-experts say I will be 6000 + on the Rpm with the 25" prop. Its your hand on the throttle ,,not the prop !!!!DDUUHHHH |
I spin 5000rpm with tuned B1 26P props behind 6.2 bone stock engines with 1.65 D/R . I'd start no less than 28P with your setup.
Ps; Kidnova on Speedwake has a 23 Nova with 502 .Less power but could give you some pointers on prop selection. |
