Prop size for 600HP
Prop size for 600HP
Please only been there done that suggestions…………………………………
Ok I need a starting point. 23' Wellcraft Nova don’t have any Idea on what prop to start out with This is what I have 4000# deep V cuddy hull with a DYNO 502 640HP at 5800 and 624TQ at 5000 without accessories. Bravo 1 with 1.5 ratio. I ask Throttle Up they had no suggestion on props they only do CNC props. Therefore, do I want 3, 4, 5 blades, what hub…what pitch and labbed or not and what brand?
As I stated you want high rake props, like a Bravo I . If your drive height is original then 3B or 4B props will be the ticket. Your drives need to be pretty high to run 5B props.
Julie
Julie
I have a 3b 25 Mirage that cam with the Bravo 1. I don’t want to go out spin over the 5800 + to max rpm to find out I don’t have enough prop. Which some non-experts say I will be 6000 + on the Rpm with the 25" prop.
So why not throw the 25 on it and see what happens?? It would give you a good starting point.
1 Post
I spin 5000rpm with tuned B1 26P props behind 6.2 bone stock engines with 1.65 D/R . I'd start no less than 28P with your setup.
Ps; Kidnova on Speedwake has a 23 Nova with 502 .Less power but could give you some pointers on prop selection.
