Help!!engine overheating
I potsed a thread earlier and am going to back flush( I sucked up buckets of sand) from the manifolds, take out the engine drains, replace the impellar, replace thermostat, Do you think I should replace the water circulation pump? For $200 i didnt want to do it for nothing ya know. Thanks
Isn't there in impeller in the circulation pump - I would replace that.
^^^^^ What He Said ^^^^^
You can remove the circ pump and then remove the back cover to inspect it. The impeller is metal so, I doubt there is anything wrong with it.
Originally Posted by Griff
(Post 2861794)
NEVER KNOW ,,i quess .:rolleyes: |
(Post 2861794)
(Post 2861794)
I would be more worried about getting the various coolers ( fuel, p/s, oil)and the ex manifolds cleaned out good. |
