New Fuel Tank: How much?
Old 05-08-2009, 12:21 PM
rtaylor's Avatar
Default New Fuel Tank: How much?
Any rough estimates on how involved and how expensive it would be to take a 27' boat with a fiberglass fuel tank, open up the floor, clean it out, and place a new aluminum tank might be?
Thanks.
rtaylor is offline
Old 05-08-2009, 12:46 PM
Dayum we're gonna have to start callin you Scotty Sunkin
U know that $1,000.00 dont buy alot of shop or refinish time
Old 05-08-2009, 01:01 PM
Not sure about the labor part, but I just had a 260gal aluminum tank built for $3200.
I would venture a guess to say that your tank is not that large. It definitely pays to shop around. I had estimates from $3200 to $6500+ for the same tank.
Philm is offline
Old 05-08-2009, 01:27 PM
lucky strike's Avatar
Fabricate 1 aluminum 110 gal tank..... $1100
New floor exactly like original. All new hoses & fittings. $4,000.
I don't think I got a deal but it is perfect like new.
. It was a very big & messy job on a 31 Sutphen, had to chop the floor out
lucky strike is offline
Old 05-08-2009, 01:36 PM
Sea-Dated's Avatar
PM Masher44 on here. He had this done in his Activator last summer.
Cut floor out, made custom tank and put it all back together again. I can't remember what he said it cost him.
Sea-Dated is offline
Old 05-08-2009, 01:48 PM
Received 1,821 Likes on 907 Posts
Itr will probably depend a lot on what needs to be done to the floor. On my Pantera, the center section of the floor that covered the tank was a separate piece that could be easily removed and then screwed and caulked back in. If you've got to cut and reglass, its gonna get more expensive.
Griff is offline
Old 05-10-2009, 07:57 AM
They should all be like that...
Pismo10 is offline
Old 05-10-2009, 08:08 AM
TomFTM's Avatar
Randy, I guess you checked the fittings on the tank?
Is the floor finished with gelcoat or just fiberglass then painted?
The tank for my 27 was $900 3/16" alum 4 baffles . Had it made on here on LI .Any questions give me a shout .
Tom
TomFTM is offline
Old 05-10-2009, 08:13 AM
I removed mine last fall. Pics and process can be see here...http://www.offshoreonly.com/forums/s...n-ongoing.html
I had a new tank (131 Gallons) fabricated for $900, Pourable foam $200, my labor.....priceless!
Good Luck!
502ss is offline
