MSD 85551 vs MSD 8560
Old 05-11-2009, 11:07 PM
Default MSD 85551 vs MSD 8560
I currently have the MSD 85551 distributor on my engine application and I wanted to know if you guys would replace it with the marine 8560 - If so, why?
I'm asking because I want to see if it worth the money replacing...
Gary
whtnordic is offline
Old 05-12-2009, 08:45 AM
Your engine will not know the difference.
BenPerfected is offline
Old 05-12-2009, 08:50 AM
SORE MEMBER
Wobble's Avatar
Same components inside, different connector, the 8560 is somewhat weather tight and has a weatherpack connector.
Not worth spending the bucks.
Wobble is offline
Old 05-12-2009, 08:59 AM
Default MSD Dist
I appreciate the feedback - I just thought there would be some long term effects once I go back and forth from salt to fresh water. I didn't think I would loose any performance, I was just worried about vibration and moisture ruining the components - I'll keep it the was it is until I have to replace them - thanks again,
Old 05-12-2009, 09:03 AM
SORE MEMBER
Wobble's Avatar
the push type connector on your distributor connector would benefit from some dielectric grease to limit corrosion.
Wobble is offline
Old 05-12-2009, 12:06 PM
They also have vent screens in them.
fbc25el is offline
