o2 sensor location
I am putting an O2 sensor in a 1997 Mercruiser 7.4 liter MPI equipped with corsa captains call exhaust, Could someone recommend a location for this sensor.
Originally Posted by blr
(Post 2870904)
Are you saying to put the sensor on the downstream side of the butterfly valve in the captains call exhaust, if so then how do I get a reading if the butterfly is in the closed position.
Thank you Brian |
No good if its a wet exhaust.
Yes it is a wet exhaust, however I have done some mods to the engine and I need to change the parameters in the ecm to reflect these mods so I have to obtain a fuel air ratio readout using the o2 sensor just for the period of time to make the parameter changes.
Won't work unless you read directly in the exhaust port w/ no water.
OK that is fine but where can I install the sensor in the exhaust with no water present?
(Post 2871078)
Thank you Brian |
Put the bung in the riser just after the manifold. You have to keep the sensor as far as way from the water as possible. Not only will the sensor give you a false lean reading by picking up the oxygen in the water, but it will kill the sensor. The O2 sensors are highly allergic to water.
It needs to be just after all of the pipes converge. You do not have to weld it inside in out. Drill a hole in the pipe. Then take the rounded end of a ball pein hammer and put it on the pipe in the hole. Hit the hammer with another one and it will cause the hole to dimple in just a little. This will help close up the gap between the two pipes. Then you can weld up the gap between the pipes and seal off the water. Once you have the water sealed up, then set the bung on top of the pipe and weld it in place. You do not have to weld the inside because you have sealed up the water already. It's hard to explain typing, so if you do not understand or if I didn't explain it good enough, give me a call and I will walk you through it. Eddie |
You would have to put it where there is no water. In your cast manifolds there is no place for a O2 sensor( at least not that I know). To weld a bung in would be hard. You would have to go thru the water jacket then into the ehaust stream. To get a accurate reading of just one side of the engine. It would have to be where the runners combine before where the water mixes in with the exhaust.
The only place I know of to mount a sensor in stock cast iron exhaust is the bottom side of the manifold near the exhaust port. If you take a stock manifold and turn it over you will see how the paint is burned about a inch or 2 back from the exhaust port,the manifold is single wall at this point,you drill and tap the manifold for your 02 sensor at this point. Put a sensor in #7 and #8,tune for whichever one reads the leanest,don't get to crazy trying to tune it too exact as your not getting a true average of all the cylinders. This is how Tyler Crockett had me mount mine in my stainless marine 3's and right or wrong it has worked for tuning,Smitty
| All times are GMT -5. The time now is 04:09 PM. |
