-   -   Wants to put freshwater boat in Ocean (https://www.offshoreonly.com/forums/general-boating-discussion/213988-wants-put-freshwater-boat-ocean.html)
motoboy 07-30-2009 01:36 PM
So my boat is up here in Michigan on a painted trailer. In the Winter I'd like to take it to my Dad's place in Stuart FL.
How do I get the boat off the trailer in Florida without exposing the trailer to salt water. Eagle says warranty is void if put in salt water.
Can the forks of a Wiggins fit between the boat and trailer and lift it off??
Thoughts??
thanks!
mb.
JasonSmith 07-30-2009 01:39 PM
Yes
Wild 07-30-2009 01:42 PM
if it doesnt fit then they hand lifting staps off of the forks around the bottom of the boat
CasinoRunner 07-30-2009 01:48 PM
Yup, what Wild said....make sure they use the straps.
Wild 07-30-2009 01:49 PM
3 Attachment(s)
like this
motoboy 07-30-2009 01:58 PM
that would work...... Thanks!
curious how they get the straps between the trailer bunks and the boat.
Would hate to trailer 1,300 miles to Florida and can't use the boat. :angry-smiley-038:
mb.
BraceYourself 07-30-2009 02:10 PM
mb.
If your bunks don't stop and start then use a couple yard arms and your set.
joew. 07-30-2009 02:20 PM
Not to be Mr. negative but if you have a 27 ft baja and they charge $10/ ft to lift the boat ( each time). That is almost $600 for one trip. If you wash the trailer and keep it maintained you should be fine. Not a lot to boat trailers that can cost more then 600.
my .02
northernoffshore 07-30-2009 02:31 PM
put in it where there is fresh water down the river and joy ride it home.
Dean Ferry 07-30-2009 02:39 PM
I have 2 steel trailers for my both of my boats, they came that way, as they were both back repos. But that being said, the Nordic trailer doesn't get used that often, had it 5 years now, and it's still servicable, (Nordic sits on the boat lift behind the house. My hydrostream has a 2007 "Boat rite?" steel trailer under it, and I dunk that thing twice a weekend, in salt water, and I FLUSH it just like a boat engine, (haven't built a lift for the hydro yet). Plus before I put it the salt water for the 1st time, I cleaned it and sprayed Boeing T-9 all over all the components, except the carpet bunks. Works for me, has for many years here in Florida.
Dean
gerritm 07-30-2009 03:53 PM
I have an Eagle trailer and have put my Fountain in salt water 50 or 60 times with it. Rinse it off real good including the drain holes in the back and sides. Wax the painted surface. After constant dunking like I did before I put it back on a lift you will see a few small rust spots. A couple of dunkings will be no problem if you RINSE it immdeiately after, especially when the boat is off the trailer. As far as the fork lift, they will lift the back end of your boat, just enough to slide the strap in and then lower it and pick it off the trailer with the straps. They will usually put it on a rack and again lift it with the forks and drop it in the water. I would go to the local dry dock marina and see if you can make an in and out deal for the few times you will be there. With the slow economy most will be willing to earn a little extra. Good luck and have fun.
H20 Toie 07-30-2009 04:17 PM
Just use the trailer and wash it off. as long as you rinse it off it will be fine.
Jupiter Sunsation 07-30-2009 05:36 PM
Dean
+1
You should also consider the trailer. If it is an 01 no harm splashing and rinsing it real well, it is already 8 years old and probably not mint anyway. If it is an 08 I would be more cautious.
motoboy 07-30-2009 07:09 PM
Originally Posted by Jupiter Sunsation (Post 2921816)
+1
trailer's only 2yrs old. Boat was rack stored prior to that.
thanks for the reply's! Hopefully this Winter I'll be posting wanting to know the good spots between Stuart and Miami. :evilb:
mb.
offshoresteve 07-30-2009 07:16 PM
Spray the trailer with Salt Away !!! I have been using my steel Skater trailer for 5+years without a problem probably dunk it 20+ times a year in salt water.
jima97 07-30-2009 09:37 PM
I second the Salt Away. I use it every time.
young-gun 07-31-2009 12:53 AM
If you really don't want to put the trailer in, look around for used good condition trailers or even look around to see if you can rent one.
Indy 07-31-2009 05:45 AM
I guess those that have done it know better (salt-away etc.) but my steel Nordic trailer started rusting the first day I dunked it. I had no way of rinsing the trailer off after I launched the boat so it sat for 5-6 hours unwashed until I came back, loaded the boat and washed everything. I washed it thoroughly and inside the box frame as much as possible but it was a mess after a short time, and I mean 3-4 dunkings. The little dings from road debris started first and got a foothold along with inside the box frame. Never again will I own a steel trailer...what a waste of money. All boats that I now buy will have an aluminum trailer or no deal.
I'd have it lifted off or unload it in a fresh water canal or something, not worth the headache, and if something goes wrong and the trailer manufacturer sees that you had it in salt (not hard to tell) you're up the creek...not worth it imho.
