-   -   Mercruiser scan tool (https://www.offshoreonly.com/forums/general-boating-discussion/21513-mercruiser-scan-tool.html)
SeaDated 04-03-2002 11:26 AM
Help help, where is the best place to get a scan tool?
Jan 04-03-2002 11:58 AM
Here is the company that makes them, not sure if you can buy direct.
http://216.230.203.183/marine/mtspec.htm
Jan
Revelocity 04-03-2002 04:50 PM
Rinda Technologies oem's some scanners for Mercury and will sell direct.
www.rinda.com
Dreamweaver 04-03-2002 05:34 PM
SeaDated - I might be able to get this for you... I'll check.
SteveDavid 04-04-2002 12:01 AM
SeaDated,
You're welcome to borrow mine. It's the older version, works fine on 500 EFI's, etc. There is a newer version with changeable cartridges for various installations and I believe even more data capture.
Mine displays about every variable the ECU processes. I can send it to you after the 15th. if that's not too late for you. (Dustin is in town the 14th. and we'll need it for various tests that weekend, after that you're free to use it as long as you like.)
Steve
28Eliminator 04-21-2002 01:28 PM
It looks like the DIACOM PLUS software is the hot ticket if you have a laptop computer. You could hook it up and monitor problems while cruising in the boat, when you have an ntermittent
problem that only occurs under load.
A question? It looks like these only monitor the status of the computer and sensors. So how do these builders and aftermarket HP guys reprogram the computer?
1. Do they just use special software on a computer and a special
interface cable like newer cars.
2. Do they program a chip and replace it like older cars. I think not
Mmmmm, I'm sure a lot of people on the board are wondering the same thing. Inquiring minds want to know.
Smitty 05-14-2003 12:16 PM
I called Rinda and they quoted me 399.00 plus tax.
C_Spray 05-14-2003 01:29 PM
I was thinking (I know...I know...)
After struggling with a notoriously unreliable fuel gauge for several seasons, I've been thinking about installing fuel flow meters/totalizers in my boat. The problem is that the "over 500 hp" FloScan units are :crazy: expensive. Since my boat uses GM EFI, wouldn't a scan tool like this give me what I am looking for (and then some) at far less $$$? Just need to figure out how to mount a couple of them on the dash without it looking too unsightly.... :rolleyes:
