Like Tree0Likes
Does anyone have one of these (trailer rim)
Old 08-29-2009, 02:34 PM
My Boats: 94 32' Fever, 81 30' Shadow Cat
Default Does anyone have one of these (trailer rim)
I went back to finish the brakes on my trailer which had been taken apart at an earlier date. Upon my arrival I noticed someone had stolen my rim and tire. This is really throwing a damper into my plans and I'm scratching to get the boat done for Lake George. Money is tight and I cant afford a set of 4, 8 lug wheels. Let me know. The rim is 16.5 and takes a 9.5 tire. The trailer is running out of life but I still need at least a few more trips.
prostock85 is offline
Old 08-29-2009, 10:07 PM
Charter Member #232
Audiofn's Avatar
My Boats: 1979 Formula 302, 99 Formula 353, 81 Donzi 18 2+3 with 454
If you are just trying to get up and running who cares what kind of rim it is as long as it is sized correctly. I think that Champion Trailer will have very close to that.
Put your best foot forward!
Audiofn is offline
Old 08-29-2009, 10:22 PM
My Boats: 2002 38'Ocean Express Catamaran
That is an Outlaw rim.
Try this : This is google. You should be able to find one easy.. I have the same on my old boat trailer..
http://www.google.com/search?sourcei...&q=outlaw+rims
mmareno is offline
Old 08-29-2009, 10:33 PM
Thanks for the replies. I have been doing a little research and it looks like I can use a set of rims and tires from any pre 97 ford 2 or 350. Seems the offset is within 1/2" and the tires are load range E. 8 x 6.5" pattern. Any thoughts?
Old 08-29-2009, 11:25 PM
My Boats: Pair o' 700's in a 36
As long as your not on a single axle trailer, you can get away with using car tires on a trailer. With single axle you might get sway problems, or impact transfer through the wheels/tires because the tires will not flex as much as a trailer tire will. But in the case of Tandem or Triple axle trailers, the weight is more even distributed, so you will have far less of a problem.
Some will argue for and against. I would say yes your ok to tow as long as you are not overloaded. Keep an eye on your tire condition and pressures.
I would recommend replacing with trailer tires when you get a chance, but not necessary for your trip.
SmurfOnABoat is offline
Old 08-30-2009, 12:26 AM
jeff32's Avatar
My Boats: 2000 triple 500 efi Sonic 45
16.5 wheels are hard to find.. been there , done that...
jeff32 is offline
