-   -   Stabill vs Seafoam (https://www.offshoreonly.com/forums/general-boating-discussion/217899-stabill-vs-seafoam.html)
DisturbedVelo22 10-03-2009 12:46 AM
Originally Posted by BenPerfected (Post 2965270)
How does anybody know both aren't "Snake Oil"? Some years we have added nothing to the fuel and not had any issues...winter down time has been mostly 7-8 mo.
I've had the same thing, some winters I add nothing, some years I put stabil in and haven't noticed a difference between the 2. Then again I only have a 60 gallon tank and the first few trips I baby it until I add fresh fuel anyway either way.
Wobble 10-03-2009 08:34 AM
most modern fuel injection cars have a sealed fuel system, the tank is not vented therefore the aromatics in fuel can not escape. Most boat and carbureted systems are vented to the atmosphere and the fuel will degrade in as short a time as six months depending on the the storage conditions and vent size.
The alcohol in modern fuel is the first to go and causes bad corrosion in the process. I personally highly recommend stabil or similar and or draining the carb on anything that is going to sit more than six months.
I have lost count of the carbs I have had to remove and clean for friends
DisturbedVelo22 10-03-2009 07:51 PM
Originally Posted by cuda (Post 2965414)
I put nothing in the gas. My fishboat has gas in it that is at least three years old. If it doesn't smelll like linseed oil, it's good to go. I sold my Formula with some three year old gas in it, and it had 10 to 1 compression. It started up, and ran fine. I think you are buying a bill of goods with additives in your gas, unless the bitter cold affects it. I also never understood changing the oil every spring. Oil doesn't just go bad by sitting. How long do you think oil is sitting on the shelf before you buy it?
I change it every fall before I put it away and it looks pretty dirty for the amount of hours I put on it. The only reason I do that is I don't want the contaminates to form sludge and coat my engine parts.
GO4BROKE 10-03-2009 08:00 PM
It is changed in the spring for condensation, not oil degradation. I don't bother anymore. Mobil 1 is supposed to handle high moisture content, one good run to get it hot boils it out.
GO4BROKE 10-03-2009 08:01 PM
Also Stabill cleans injectors, I figure it can't hurt.
