Like Tree0Likes
The Birth of a Race Boat
Old 10-13-2009, 06:16 PM
  #51
dammmagnum's Avatar
My Boats: Magnum Sport -27 Sport
[QUOTE=glassdave;2972187]Autoclaves work on positive pressure not vacuum. When combined with a vacuum bagged laminate the part is first layed up, completely bagged and vac'ed of any air voids then placed in the autoclave and kept under full vac pressure until the autoclave reaches its peak positive pressure or vented to the outside atmosphere. When pressure is applied the process kind of works in reverse of the original vac bagging. If that makes any sense
Also think of this. How would you heat it if it were a vacuum?
that a cool website on the 787 by the way. Its amazing the fuselage parts are built all around the world then brought together in WA. Thanks.
Dave,
A few years back we used autoclaves to laminate printed circuit boards used in all elecronics euipment.
we would use C stage core material(cured) with the copper circuits on it and bond them together using B stage pre-preg sheets.
We would lay them up in steel fixture plates to maintain registration of all the layers and then vacuum bag them and then put many of these fixtures iinto the autoclave and pull vacuum and then heat CO2 or nitrogen to about about 350F to make the pre-preg flow and cure. we also also post bake the boards in a std oven for final cure
This was just a simple version of what we did.
One of the advantage of the autoclave for us was that we could laminate different size fixtures in the same press load.
but the autoclaves never really caught on with the PC industry
Prior to Autoclaves and today we use a vacuum assisted Hyd press using heat and pressure to laminate the PC together.
Sorry running off at the fingers
Thank you
Jim
dammmagnum is offline
Old 10-13-2009, 06:38 PM
  #52
Neno the mind boggler
Trade Score: (1)
glassdave's Avatar
My Boats: Batboat, 38 Scarab Thunder, 16 Sidewinder, 27 Magnum
I've heard of some inert gasses being used in other industrial autoclave processes for the pressure side. Theres all kinda uses for these things.
08 OPA High Points Champion
glassdave is offline
Old 10-13-2009, 11:44 PM
  #53
My Boats: 1991 cigarette 42' revolution with 3-750 hp hawks and ssm drives,2009/1979 cig 35' mistress [for sale]
how thick is the hull when done?,,and how thick are the sheets of cf?,,how many layers?
dmaxx3500 is offline
Old 10-14-2009, 12:09 AM
  #54
dammmagnum's Avatar
Quote:
Dave
Yes, we used either CO2 or Nitrogen
which was a pain as we had to have large storage tanks, plus both CO2 and Nitrogen are super cold and then have to heat them using a electric heating element to 350F,, the heat rise was fairly slow
Thank you
jim
Old 10-14-2009, 02:31 AM
  #55
Trade Score: (3)
My Boats: 22 Avanti, 25 Nova, 2 turtle doves and a partridge in a pear tree,SBYC
great thread by the way.
I saw that on 60 minutes a while ago...boeing actually wants to bring the manf. back to the states..to many issues with tolerances/qc etc. They figure the decreased costs of less problems will negate the costs of us manf. some things are just to sensetive to outsource.
phragle is offline
Old 10-14-2009, 05:45 PM
  #56
animalhouse's Avatar
More stringer install
The Birth of a Race Boat-100_0289.jpg   The Birth of a Race Boat-100_0291.jpg   The Birth of a Race Boat-100_0292.jpg
animalhouse is offline
Old 10-14-2009, 05:59 PM
  #57
Cockpit completion and roll bars for canopy
The Birth of a Race Boat-100_0295.jpg   The Birth of a Race Boat-100_0290.jpg   The Birth of a Race Boat-100_0294.jpg
Old 10-14-2009, 06:00 PM
  #58
check out the carbon seats and the recessed rear seats. The aluminum is in there for harnesses.
Old 10-14-2009, 06:19 PM
  #59
LOOK AT THE LEAD NOW!!!!!
DPT MOTORSPORTS's Avatar
My Boats: boatracing,motorsports,boating
Thumbs up
Just curious on what materials you guys are usung for the stringers?
Thanks,
DPT
DPT MOTORSPORTS is offline
Old 10-15-2009, 08:44 PM
  #60
Laminating the rest of the stringers, that solid sheet is ready to be cut up for bulkheads, and finally Joe checking out the progress.
The Birth of a Race Boat-100_0300.jpg   The Birth of a Race Boat-100_0303.jpg   The Birth of a Race Boat-100_0307.jpg
