-   -   Whipple 700SCi Upgrade (https://www.offshoreonly.com/forums/general-boating-discussion/219751-whipple-700sci-upgrade.html)
BKSAE 11-08-2009 12:37 PM
Anyone have any first hand experience "GOOD & BAD" with the upgrade kit for Mercury 700 SCi and what does it involve. Did any measureable difference in performance occur with upgrade. Thanks for your input.
CB-BLR 11-08-2009 02:48 PM
Do a search on this...
For both 600sci and 700sci.. basically the same engine with different cams.
Usually about 8-10 mph increase.
The Whipple upgrade is a first class product.
I love mine!
Chris
P.S. The only negative is that you are probably going to need bigger props :evilb:
cbradley 11-08-2009 04:42 PM
had it done a little over a year ago. took the boat from a 100 mph boat in perfect conditions light fuel light load to 100 any conditions and a best speed of 109. same props, they just spin a little higher which is ok since the whipple ecm reflash raises the rev limiters
BKSAE 11-08-2009 05:15 PM
Run Time
How many hours of use since you had it done. No issues I take it? Thanks in advance.
gnorthga 11-09-2009 09:09 PM
you know I just really like not worring about the boat breaking it runs 105 now and I never think about anything but keeping it serviced
Turning up the boost makes me think the motors are not going to last and the NXT trans might break we are planning trips to Keys and Bahamas and dont wont to have problems
C_Spray 11-11-2009 04:13 PM
Originally Posted by gnorthga (Post 2988429)
....and the NXT trans might break...
Bingo! Give that man a cookie. That's the real question about this particular upgrade. It's like putting a blower on a 525/Bravo package. The engine will probably be fine, BUT....
Back4More 11-11-2009 04:18 PM
There is a proven method to upgrading to new trannies...takes less power to turn them too.
CB-BLR 11-11-2009 05:53 PM
Please enlighten us.
Chris
gnorthga 11-12-2009 07:42 AM
My I ask what rpm you turning at 109 and what is the manifold pressure
gnorthga 11-12-2009 08:07 AM
I am sure there is a way to do anything, but this is a sweat boat, just like it is and I love it.
I am very happy with it.
I go to several runs a year and yes some people go by me also they break a lot of times and I wind up ahead of them at the end of the day.
I am just like the next guy I want to go faster, but this boat will cruse at 85 mph making
5 lb. of boost all day. I came from a Scarab 26 that was about wide open at that speed
My last boat 35 lighting was really taxing the motors to cruse 85 mph all day.
My concerns are as follows:
1.) How much re-freshing (bottom or top end) do you have to do when you turn them up
2.) Will the Trans/clutch handle it
3.) I do not want to go back to pulling motors in and out of a boat again
Back4More 11-12-2009 03:25 PM
The new trannies set the motors forward a bit.
Strip Poker 388 11-12-2009 10:53 PM
so thats kinda a rerig. filling in the motor mount holes in the stringers.Would that be a rear motor mount also???
:drink:
Rob
Got Freedom? 11-18-2009 05:45 PM
Yes, you need to install a rear motor mount on the close-coupled engine and drill new holes in the stringers along with a few other changes.
aTX427 11-18-2009 06:14 PM
Have you changed yours out?
aTX427 11-18-2009 06:16 PM
How much power will the NXT transmissions support?
Strip Poker 388 11-18-2009 10:21 PM
can you post a full size pick of your avatar:drink:
Got Freedom? 11-19-2009 04:40 PM
1 Attachment(s)
I like that picture too, here you go.
Got Freedom? 11-19-2009 04:44 PM
Yes, I swapped my NXT transmissions for Huber 1450s. According to the Mercury Racing shop manual the NXT transmissions are rated for 800 ft lbs of torque.
gnorthga 11-19-2009 07:26 PM
I guess you would recommend doing that before doing the upgrades?
What kind of torque does the whipple 700 upgrade give you?
TeamSaris 11-19-2009 08:05 PM
We did it on a 353 formula with 600s, boat now runs over 100. Very sucessful
Whipple Charged 11-19-2009 08:09 PM
Motors have 7.5:1 compression which is very, very low, more boost, as long as controled with the proper fuel, spark and air discharge temp out of the intercooler is actually very safe.
Whipple Charged 11-19-2009 08:12 PM
The hardest thing on the engines is RPM, not boost. So if you want to keep your engine close to stock hours, then you'll need bigger props if your going to constantly be running top speed. For most, they just occassionaly take it up and this has very little change on the life of the motor.
Trans and drive has proven to handle the power.
You do not need to pull the motors all the time, even in stock form, the first thing to go is going to be the valve train, followed by head gaskets, so you should rebuild these around 300-400 hours no matter what.
Whipple Charged 11-19-2009 08:14 PM
The 700 stage 2 gives you just over 800lbs of torque, but this can also be dialed in to whatever you want.
customryder 11-19-2009 09:07 PM
can you do anything to whipple charged 525s without lowering boost to help save a xr drive?
Whipple Charged 11-20-2009 11:48 AM
If you want less torque, we can take timing away at lower speeds. Torque is also dependent on how much throttle you give it so you can always give it less throttle. You only reach peak torque when your full throttle.
cbradley 11-20-2009 02:46 PM
Dustin:
I think I had it told to me there were some tweaks and upgrades to the ECM program since I had mine done a year ago. Is this the case?
