-   -   42' Epoxy OL, your opinion? (https://www.offshoreonly.com/forums/general-boating-discussion/222818-42-epoxy-ol-your-opinion.html)
pm203 01-16-2010 11:32 PM
Maybe I will just take a ride to RI.
Catmando 01-17-2010 12:29 AM
Originally Posted by pm203 (Post 3025319)
Don't forget, epoxy boats ride a little harder also.
Indeed. Teague tested a 42 and he said it was like driving a block of concrete. :eek:
OL40SVX 01-17-2010 12:31 AM
I've been in them and its not like that at all.
PatriYacht 01-17-2010 09:36 AM
As far as the appearence goes, the gelcoat on the deck of a dark colored boat will expand, buckle and crack eventually on almost any boat. I've seen it on everything from a Wellcraft to a Skater. Stick to lighter colors if you want to avoid this problem.
Jassman 01-17-2010 09:38 AM
I have also.. The boat is one of the finest made, does many things great, better than 90% out there... it does so well cause they are light, and built like a brick sh!t house.. the penalty is a stiffer ride vs the vinylester boats. It all depends on what you're looking for, intended purpose of boat built, and pocket book. Would I own an OL..sure..but prefer Mike's glass boats better with some of the new technology.
Sean H 01-17-2010 09:41 AM
Does OL build any new boats out of VE? I know they build both glass and carbon, but do they switch resins as well?
Jassman 01-17-2010 09:52 AM
that would be a question for Fred.. I un-like most, prefer a softer ride and am not interested in getting the last mph out of my boat. In return I'm well aware that the ride I got from Mike and Fred was as good as it get's at 80+mph in 4-5's could not be achieved in a glass boat. It helped that Mike was driving also...OMGSMP. LOL
Panther 01-17-2010 09:53 AM
Speaking of Epoxy boats... They all seem to be painted and scratch easily, why? Compared to a VE or Poly boat they have gelcoat... Do they make a Epoxy gelcoat if someone doesn't want to paint the boat? I've seen quite a few Epoxy boats 2-3 years old and they're going for paint touch-ups, fade spots and/or clearcoat fixes.
customryder 01-17-2010 10:19 AM
i have only been in a 39gtx.. very stiff and noisy under-way.. sounded like the bottom was comming apart.. something you get use to i guess.
Steve 1 01-17-2010 10:23 AM
Yes there are Epoxy Gelcoats and they are easy to use but they are in a off white, Personally I like Paint, Awlgrip for one,
it is this way with Paint 2-4 Mills gets you covered, Now gelcoat at 12 mills there are still shadows so we spray between 18 and 22 wet with Production Material to get the proper coverage.
Now that said It does provide a Durable surface but it carries a huge weight penalty when you include the check or skin out mat. and since it is chemically bonded (in the ester world) if it cracks guess what? the laminate can be damaged as well.
