Originally Posted by Austin
(Post 3030286)
Strip... I think I se a spot on one of those! Just kidding. I see you take very good care of your motors. So- just to be clear... I can spray my motors with cleaner ( simple Green) and then hose them down with water?? Then after that spray them with CRC 656.
Yes Austin, simple green will work. For stock motor finishes the Gunk degreaser may perform best as it foams to loosen belt dust build-up, ect. . Rinse with low pressure hot water if possible for best results (AVOIDING THE IGNITION COMPONENTS), then use a corrosion protector such as CRC. |
How does a boat motor get this bad? Its not like there is road grime or other things passing through the vents? Did it blow up? I can understand a little build up on the intake from blow by or crank case ventalation, but not so much that you are looking for things that are generally used to clean a diesel in a big rig.
I think in my case it was that I used a wax type corrosion inhibitor and over time dust and just general crap stuck to that. TxHawk- they're not that dirty, but, I just really enjoy looking back at clean well maintained motors. Why let them get dirty and corroded ... just wish I had learned this "lifes lesson" at 15!
Thanks for all the replys- it's a perfect Sunday to be in the bilge. |
Originally Posted by Kelly O
(Post 3030447)
Strip's display is VERY sweet!!
I use S100 on my Harley. Spray it on the cold engine, hose it off and use my leaf blower to dry it. Stuff is awesome.
Has anyone tried S100 on their boat engines? |
1 Attachment(s)
Simple and easy way...just use Dawn and water, cuts grease and doesn't hurt anything:drink:
(Post 3030447)
Yes Austin, simple green will work. For stock motor finishes the Gunk degreaser may perform best as it foams to loosen belt dust build-up, ect. . Rinse with low pressure hot water if possible for best results (AVOIDING THE IGNITION COMPONENTS), then use a corrosion protector such as CRC. Thanks,I used simple green on a company truck,it ate the paint on the air cleaner,valve covers etc,I probaly used it straight bake then. Ive never used any kind of protectant on the motor,it attracts dust ,makes it greasy looking then ya half to use a degreaser,I dont see much salt water during a year,there is no bare metal that could rust. The only thing I hate is water spots,thats what messes up the polished aluminum,Thats been a reason to pull motors in winter just to repolish them.Brake cleaner works good also. as for the bilge I will use gunk if its a spill,and Dawn. Rob:drink: |
3 Attachment(s)
Originally Posted by Rookie
(Post 3030240)
Strip, your bilge is just SICK!
Drives,buffed and waxed gelcoat in the cabin and bathroom too Rob:ernaehrung004: |
Very nice looking interior you got there, Rob...
where are all the cuffs??? :coolcowboy: |
Originally Posted by jayboat
(Post 3030586)
where are all the cuffs??? :coolcowboy: Jay I need your opinion,I have a Canon Power shot S5IS,Most of the picks I take the picks are grainy/snowy looking,I mainly use auto and use some of the manual setting,same results,the flash whitens the pick/glare.I think I'm not steady with the shots,its has the image stabl stuff, Do I need to take a class and learn about the manual setting and what they do? I have a old Canon ae1program film camera it takes clear shots. http://www.steves-digicams.com/camer...is-review.html Heres a pick of my Niece,I cant tell whats causing this,its like when there is less light it takes a clearer picture.and the flash whites it out Thanks for any suggestions. Rob:drink: http://img17.imageshack.us/img17/544...2010093.th.jpg |
| All times are GMT -5. The time now is 01:41 AM. |
